bazz96
  • 49
Message 31 of 53
Re: M200 wired speed 26.90-56.35
I have just done a reset exactly as detailed
Paul_DN
  • 5.86K
  • 343
  • 621
Message 32 of 53
Hi bazz96,
Thanks for that, all levels now look exactly as they should, please give it 24n to 48 hours and see how you get on.
Paul.
bazz96
  • 49
Message 33 of 53
Ok thanks perhaps I am expecting too much from M200
conman33158
  • 1.41K
  • 121
  • 258
Knows their stuff
Message 34 of 53
It's quite simple my friend, your equipment is the bottleneck. Get the USB 3.0 to 1Gbps Ethernet adapter as suggested above, this along with your new Cat 7 cable direct to the router should give you a decent boost over 100mb and connect any compatible wireless devices via 5Ghz and this will give you decent wireless speeds. It's a good idea to split your 2.4Ghz and 5Ghz SSID on the router.
Type  http://192.168.0.1  into your URL address bar on your browser and login into the Hub with your chosen password or use the settings password on the Hubs sticker on the bottom of the Hub and set up the Hub with a new password. Then go to Advanced>Wireless>Smart Wi-Fi and tick the disable “channel optimisation” box and save settings.  Then go to Advanced>Wireless>Security and rename the 2.4Ghz and 5Ghz network SSID's.  Change them to whatever you like, for example JohnsVirgin_2 and JohnVirgin_5.  You can keep the same wi-fi passwords or use one of your choosing, then click apply settings and restart the Hub. Your two wi-fi networks will now be separated and you can select whichever network you want to connect too, for example the JohnsVirgin_2 (2Ghz) or JohnsVirgin_5 (5Ghz). The 2Ghz one has a greater range but has a slower speed and the 5Ghz one has less range but faster speeds. Be aware that some older devices will only see the 2.4Ghz SSID but most modern devices will come with 5Ghz capability.
Also please be aware that all your previously connected wireless devices will need to be connected again to your new SSID's with you new passwords or your old password if you decided to keep them.
bazz96
  • 49
Message 35 of 53
Anker USB 3.0 Portable Gigabit Ethernet Adapter Supporting 10/100 / 1000 Mbps Ethernet for Macbook, Mac Pro/mini, iMac, XPS, Surface Pro, Notebook PC, and more
is this ok £15.99 from Amazon
conman33158
  • 1.41K
  • 121
  • 258
Knows their stuff
Message 36 of 53
Yes mate👍
bazz96
  • 49
Message 37 of 53
Yes mate
got this and the cat7cable how does this work i connected and it shows that I'm using wifi is that right
conman33158
  • 1.41K
  • 121
  • 258
Knows their stuff
Message 38 of 53
No turn the wifi off on your laptop and the cable will be picked up automatically if not already
bazz96
  • 49
Message 39 of 53
ok its connected via the new cable and ive run a speed test here are the results
bazz96
  • 49
Message 40 of 53
8
 DOWNLOAD Mbps
28.13
 UPLOAD Mbps
21.09
