bazz96
  • 49
Message 21 of 53
Re: M200 wired speed 26.90-56.35
Usb 3 on the laptop super hub
  • 15.93K
  • 687
  • 1.56K
Message 22 of 53
@bazz96 wrote:
topology : Fast Ethernet LAN
speed : 10BASE-T/100BASE-TX is this ok
Get one of these
ATOLLA Ethernet Adapter, USB 3.0 to RJ45 Gigabit LAN 1000 Mbps Network Adapter with Type C Adapter f...
bazz96
  • 49
Message 23 of 53
Does this fit ont a laptop?
Andrew-G
  • 6.16K
  • 1.08K
  • 2.62K
Message 24 of 53
Doesn't matter at this stage - don't spend a brass farthing on anything until we've bottomed out the causes of the speed issue, otherwise there's a risk you'll end up poorer, and still not have got the speed problem resolved.
  • 15.93K
  • 687
  • 1.56K
Message 25 of 53
It should what laptop make and model is it?
bazz96
  • 49
Message 26 of 53
To shiva Satellite C50-A
  • 15.93K
  • 687
  • 1.56K
Message 27 of 53
It might have USB 3 if not it will still work on USB 2.0
Paul_DN
  • 5.86K
  • 343
  • 621
Message 28 of 53
Hi bazz96,
Thank you for reaching out to9 us in our community and welcome, I am sorry to hear your WIFI speed has seemed to have slowed down recently,
I have had a look at things our end and all your levels are in the green, the only thing I have noticed is your downstream power levels are very spaced out rather that clustered together as should be.
I advise you to try a pin reset first, push a pin/ paper clip in the reset hole at the back of the router while powered up, oonce pressed in hold for a timed 1 minute, do not rebbot befor during or after and allow 10 minutes to settle.
Once this is done we can look at this again to see if it has changed.
Paul.
bazz96
  • 49
Message 29 of 53
I did one 2 days ago the readings were taken after the reset so do I have to do another one
Paul_DN
  • 5.86K
  • 343
  • 621
Message 30 of 53
Hi Hi bazz96,,
Thanks for coming back, when you did the reset did you do it exactly as advised? if not could you do it now.
Kind regards
Paul.
