bazz96
  • 49
Message 11 of 53
Re: M200 wired speed 26.90-56.35
1331000000040256 qam25
2267000000140256 qam17
32750000000.740256 qam18
42830000000.540256 qam19
52910000000.540256 qam20
62990000000.740256 qam21
73070000000.540256 qam22
83150000000.540256 qam23
93230000000.240256 qam24
10371000000-240256 qam26
11379000000-240256 qam27
12387000000-240256 qam28
13395000000-2.440256 qam29
14403000000-2.740256 qam30
15411000000-340256 qam31
16419000000-3.440256 qam32
17427000000-3.740256 qam33
18435000000-440256 qam34
19443000000-4.240256 qam35
20451000000-4.238256 qam36
21459000000-4.440256 qam37
22467000000-4.238256 qam38
23475000000-4.540256 qam39
24483000000-4.738256 qam40
1Locked40.91739
2Locked40.91635
3Locked40.91335
4Locked40.32342
5Locked40.92535
6Locked40.32338
7Locked40.92237
8Locked40.32135
9Locked40.33338
10Locked40.93549
11Locked40.92951
12Locked40.34638
13Locked40.93044
14Locked40.34139
15Locked40.33635
16Locked40.34236
17Locked40.32538
18Locked40.33439
19Locked40.35639
20Locked38.95145
21Locked40.35245
22Locked38.96146
23Locked40.35339
24Locked38.93338
bazz96
  • 49
Message 12 of 53
16029990844.8512064 qam1
23940000042.8512064 qam4
34620000042.8512064 qam3
45369999143.3512064 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0000
bazz96
  • 49
Message 13 of 53
24/02/2021 17:31:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/02/2021 17:19:1Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/02/2021 15:56:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/02/2021 15:56:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2021 18:56:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2021 14:46:3noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2021 14:46:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2021 01:26:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 02:46:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 02:46:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 02:16:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 02:16:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2021 23:33:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2021 20:02:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/02/2021 10:29:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/02/2021 09:15:33noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/02/2021 09:15:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2021 03:19:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 15:44:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 15:43:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
sophist
  • 2.18K
  • 374
  • 542
Problem sorter
Message 14 of 53
Nothing really wrong your stats or log. A few post rs errors - keep you an eye how quickly those numbers grow...
Based on the info on the previous page about the negotiated speed of your wired connection, I think  a test with a different cable is the next step.
in addition, if you log into the hub and browse to “device connection status” what does it report as the speed of the connection to the pc? Presumably 100mb, but worth a look.
bazz96
  • 49
Message 15 of 53
It’s a laptop I think it’s only usb 2 I’ll check though thanks
bazz96
  • 49
Message 16 of 53
tried a different cable but have ordered a new cat 7 cable so will wait for that
but tried a speed test again with all other cables disconnected here are results
 PING ms
19
 DOWNLOAD Mbps
22.73
 UPLOAD Mbps
21.14
conman33158
  • 1.41K
  • 121
  • 258
Knows their stuff
Message 17 of 53
If your laptop only has USB 2.0 I'm guessing it probably only has a 10/100 network card to which a cable won't help but worth a try I guess. Until you have a system with a 1Gbps network card or capable of running USB 3.0 to 1Gbps Ethernet and a Cat 5e or better cable you won't really benefit from the fast speed that Virgin offer 😞
bazz96
  • 49
Message 18 of 53
it has usb 3 i think its the blue one this is a spare laptop as my better one stopped working
conman33158
  • 1.41K
  • 121
  • 258
Knows their stuff
Message 19 of 53
We can only go by what you tell us mate 🙂
Andrew-G
  • 6.16K
  • 1.08K
  • 2.62K
Message 20 of 53
@sophist Nothing really wrong your stats
Actually, the ratio of pre- and post-RS errors looks highly suspect, and the range of downstream power levels is probably beyond the hub's ability to cope. That's the thing about DOCSIS, it's 20% science, 80% magic, meaning that the whole picture needs to be interpreted/guessed.
I'll flag that for staff to comment.
