bazz96
  • 49
Message 1 of 53
M200 wired speed 26.90-56.35
My speeds have recently been getting slower i thought it was maybe Wi-Fi but when connected by ethernet the speeds are abysmal minimum of 107 would be a great improvement this is not a cheap service it cost £66 a month and soon to increase come on virgin fix this please
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 2 of 53
Re: M200 wired speed 26.90-56.35
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Disconnect all other Ethernet cables when running the test
bazz96
  • 49
Message 3 of 53
It’s the same cable I’ve always used a yellow one lol came from work so it’s quite old
I’ll try the site you said and disconnect all other cables
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 4 of 53
Also try a different Cat 5e or better cable if you have one 🙂
sophist
  • 2.55K
  • 420
  • 683
Message 5 of 53
all sensible advice so far, and you should definitely test with a different cable, but usually when it's a duff cable only negotiating at 100mb, the speeds you'd see on your device would hover at around 90mb, the fact that you're seeing speeds >100 indicate that the issue might be elsewhere.
it's worth posting the connection stats from your router - browse to your hub on  http://192.168.0.1 - don't log in, click Router Status - copy/paste the tables from the Upstream, Downstream and Network Log tabs back to this thread - you'll need multiple posts for this, the info wont all fit into a single one..
bazz96
  • 49
Message 6 of 53
Do I need to put the password in ?
bazz96
  • 49
Message 7 of 53
Tried your site  results are latency 14.1 ms jitter 4.61ms download 32.7 Mbps that’s with existing cable I’ll have to get another to test it  thanks for your help
sophist
  • 2.55K
  • 420
  • 683
Message 8 of 53
if it's a hub 2/2ac or 3 then no - just click "router status" on the first page that you see when browsing to the site.
if it's a hub4 then yes, you need to log in and browse to Advanced - router status is somewhere in there.
bazz96
  • 49
Message 9 of 53
topology : Fast Ethernet LAN
speed : 10BASE-T/100BASE-TX is this ok
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 10 of 53
Your network card does not support the higher speeds or else it's the cable depending where you took this reading from, needs to be 10/100/1000 or similar. If its a desktop PC buy yourself a faster card or if it's a laptop go for a USB 3.0 to 1Gbps Ethernet adapter provided your laptop supports USB 3.0.
