mistermajik
Message 1 of 7
M200 - wired connection constantly at 70Mbps
I have a SH3 set up with a Deco M9 mesh router system. There's a laptop wired directly into the Deco unit, which is wired directly into the SH3 - for about a week I've been getting speeds no faster than 70Mbps (and usually around 40Mbps)
Have tried a direct to SH3 connection too, and received a new router about 6 weeks ago to test this but no help.
Any thoughts from anyone?
Buffer6
  • 9.76K
  • 88
  • 605
Hero
Message 2 of 7
Re: M200 - wired connection constantly at 70Mbps
UK mainland utilisation issues, so many working from home now that the system slows down. I'm in N.Ireland and I get the best speed-tests results most of the time locally ie S.Ireland, but when taken at around the same time, the speed-tests are all showing lower results from UK mainland test sites.
gary_dexter
  • 28.96K
  • 1.77K
  • 3.79K
Message 3 of 7
Have you checked the cable?
What spec is the cable and WiFi card?
mistermajik
Message 4 of 7
Cable is a Cat6, using a USB-C to ethernet adapter to a 2019 MacBook Pro when I don't need wifi.
gary_dexter
  • 28.96K
  • 1.77K
  • 3.79K
Message 5 of 7
Could be the adaptor then.
A lot of cheap Chinese made adaptors are known to give poor Ethernet speeds.
Buffer6
  • 9.76K
  • 88
  • 605
Hero
Message 6 of 7
A USB type C port may support USB 3.1, 3.0 or even USB 2.0. USB 3.1 Gen1 is just a fancy name for USB 3.0, which provides speed up to 5Gbps while USB 3.1 Gen 2 is another name for USB 3.1 which provides a speed of 10Gbps.
if it's only a USB 2 adaptor then won't connect at anything more than 100 Mbps, sign in to your Hub and check devices connected when you have it connected to check the connection speed it should say 1000 or 100
mistermajik
Message 7 of 7
Thanks everyone for their help - turns out it was a faulty SH3, got a new one in and that's boosted the speeds.
Although I do have my suspicions on the roadworks happening outside too, both starting at the same time can't have been coincidental...
