Crossbomb98
  • 7
Message 1 of 11
M200 speed fine then drops.
Hi I have been with virgin for 2 years on the M100 package. Never had a problem with them, I play a lot of video games and never ‘lag’, I have recently started to live stream my gameplay. So I upgraded to m200 for better download and upload speed! My speed is absolutely fine one minute sitting at 213-217mbps download then next minute I feel my game go different check my speed on Speedtest.net and then I’m sitting at 20mbps I jus don’t understand why it is doing this! I have had a new hub from virgin and it’s still the same nobody can seem to help me on the phone, I’m getting really frustrated. My upload speed is absolutely fine that’s never affected it’s jus my download ! If somebody could help me I’d really appreciate it. Thanks!
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: M200 speed fine then drops.
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Crossbomb98
  • 7
Message 3 of 11
Hi I am trying to send the picture in of the broadband monitor it says it’s too big!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
Crossbomb98
  • 7
Message 5 of 11
Crossbomb98
  • 7
Message 6 of 11
Hi mate I copy and pasted the direct link have u looked pal thanks
Crossbomb98
  • 7
Message 7 of 11
If you could read the graph and let me know what’s happening as I have no idea what I’m looking at, that be great thanks mike
John_GS
  • 8.74K
  • 477
  • 772
Message 8 of 11
Hi Crossbomb98
I've taken a look today at the system, all the levels are in spec and no other issues showing.
How are you connected, wired/wireless?
Kind regards,
John_GS
Crossbomb98
  • 7
Message 9 of 11
Wired, just done a speed test and I’m on 10mbps, it’s annoying me because somethings definetly wrong, and today I have spent £300 on live-streaming equipment and I’m not going to be able to use it
Zak_M
  • 3.53K
  • 223
  • 353
Message 10 of 11
Good Morning @Crossbomb98
Sorry for the delay in response there.
How are things looking since your posted last? Have there been any improvements?
Kind regards,
Zak_M
