jldiablo
  • 15
Message 1 of 11
M200 - slow upload speed
Hi folks,
Hope you are all doing well.
After the unpleasant battles with customer service to get someone out to finish my install, I am finally up and running. The engineer had ran a new cable and tested everything before signing off. I am on M200 package, while the download speed is as expected 150-210mpbs, I am experiencing slow upload speed -  the advertised upload speed is 20mpbs average, I am only getting 2-4mbps. This is slower than my previous "slow" xDSL connection and causes issues sometime as we all WFH at the moment.
Could someone take a look at the stats for me please and advise if I need to get an engineer to fix it? I really hope I don't have to speak to the CS again.
Thanks.
3.0 Downstream channels
11387500005.09999838.983261QAM2561
21467500005.40000238.983261QAM2562
31547500005.50000038.605377QAM2563
41627500005.00000038.983261QAM2564
51707500004.00000038.983261QAM2565
61787500005.00000040.366287QAM2566
71867500005.09999838.983261QAM2567
81947500005.09999840.366287QAM2568
92027500005.19999740.366287QAM2569
102107500005.40000240.366287QAM25610
112187500005.09999840.366287QAM25611
122267500005.09999838.605377QAM25612
132347500005.40000238.983261QAM25613
142427500005.50000038.983261QAM25614
152507500005.40000240.366287QAM25615
162587500006.09999838.983261QAM25616
172667500006.00000040.946209QAM25617
182747500005.50000040.366287QAM25618
192827500005.90000240.366287QAM25619
202907500006.40000240.366287QAM25620
212987500007.19999740.366287QAM25621
223067500007.19999740.366287QAM25622
233147500007.40000240.946209QAM25623
243227500007.50000040.946209QAM25624
334267500008.00000040.366287QAM25633
344347500007.80000340.366287QAM25634
354427500007.90000240.366287QAM25635
364507500007.90000240.946209QAM25636
374587500006.80000340.366287QAM25637
384667500006.59999840.366287QAM25638
394747500007.19999740.366287QAM25639
404827500006.90000240.366287QAM25640
1Locked38.98326100
2Locked38.98326100
3Locked38.60537700
4Locked38.98326100
5Locked38.98326100
6Locked40.36628700
7Locked38.98326100
8Locked40.36628700
9Locked40.36628700
10Locked40.36628700
11Locked40.36628700
12Locked38.60537700
13Locked38.98326100
14Locked38.98326100
15Locked40.36628700
16Locked38.98326100
17Locked40.94620900
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.94620900
24Locked40.94620900
33Locked40.36628700
34Locked40.36628700
35Locked40.36628700
36Locked40.94620900
37Locked40.36628700
38Locked40.36628700
39Locked40.36628700
40Locked40.36628700
BQM
My Broadband Ping - jldiablo virgin bb
jldiablo
  • 15
Message 2 of 11
Re: M200 - slow upload speed
3.0 Upstream channels
12580000045.5000005120 KSym/sec16QAM6
23940000046.2500005120 KSym/sec64QAM4
34620000046.2500005120 KSym/sec64QAM3
43260000046.0000005120 KSym/sec64QAM5
1US_TYPE_STDMA00330
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
BQM
jldiablo
  • 15
Message 3 of 11
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.0
Config file
cmreg-vmdg640-bbt060+voc-b.cm
SFID
837728
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
837727
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
BQM
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 4 of 11
One of your upload streams is on the wrong modulation and should all be 64 QAM and you have a lot of T3 Time outs which could indicate a line fault. Have you Checked service status and also called 0800 561 0061 for the most up to date faults information in your area.
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
jldiablo
  • 15
Message 5 of 11
thanks conman, I have been reading about the upstream QAM drops on the forum and this seems to be a common issue.. I hope it is something easy to fix.
BQM link below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/4a6c016b1a2b0121f7fef07e6bf72311512993f2
BQM
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 6 of 11
The QAM does change depending on line noise but because you have T3 Timeouts it points towards a line fault. Your BQM will hopefully show something but will need a few hours to populate, typically overnight to build a picture of what's happening 🙂
In the meantime you can try calling it in. Best to ring Virgin on or just after 8am on 0345 454 1111 or alternatively you can wait here for a Virgin staff member to pick it up, but unfortunately this will typically be between 5-10 days, sometimes sooner, sometimes later depending on how busy they are. If you decide to call it in it will run through a few automated options and after that ring back again and it should recognise that you have rang previously and then put you in the queue for a Virgin representative.
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 7 of 11
Your BQM does not look too good so far mate, it could be a case of over utilization 😞
jldiablo
  • 15
Message 8 of 11
ye.. seems to be all over the places.. not sure about others but at least compared to yours.
Over utilization in terms of my end or Virgin's end? Is this something an engineer can help?
cheers.
BQM
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 9 of 11
It's a case of too many customers on the system, Virgin are over subscribing and lockdown is causing to much of a load on the network. It's a never ending story with VM at the minute as the network is dealing with a load like never before with people working from home, home schooling, Netflix, Amazon Prime and Gaming threw into the mix. I think Virgin are hoping after lockdown it will settle down but until then you’re stuck. You can ring Virgin about this with maybe a fix date for the future but to be honest they have a tendency to apply fix dates only to keep moving them forward and then ending up with nothing being done for months at a time or simply hoping people leave freeing up the network or again hoping that things improve after lockdown. If your new to Virgin you have a cooling of period within 14 days giving you the right to cancel, you'd be better off giving them a call in case it's a line fault but judging by your BQM is shows that it settles in the early hours then back up again during busy hours.
jldiablo
  • 15
Message 10 of 11
Thanks for the explanation. Something I really hope it is not the case but makes sense. However the weird thing is that the download speed doesn't seem to be affected that much... I wouldn't mind for the download speed to drop a bit to maintain a more usable upload speed.. Can virgin do something to free up some download channel for upload?
I do have virgin TV and phone as well.. could it contribute to the issue? e.g. taking up bandwidth? TV box throwing noise to the line etc.
Would running the hub in modern mode help? I do have a more powerful router but I wanted to get any issues resolved before configure everything in modern mode... saw a lot of threads asking people to switch back to Router mode for troubleshooting...
BQM
