Pmartin2
  • 8
Message 1 of 16
M200 slow speed
I signed up to m200 ignorantly expecting to get 200meg speeds as advertised. I'm only getting 70 when i connect my laptop to the hub 3 with a cat5e cable and with it being the only thing connected and yes it has a gigabit port. Before i spend hours talking to someone in the arse end of knowwhere, that's not likely to be able to help me anyway, from customer services i thought i would have an ask on here if there are any things i can try to get nearer the 200 or have i been to ignorant and am never gonna get close.
I'm not that computer savy but i can usually find my way around when i need to so any help would be appreciated. Thanks in advance.
Tags (4)
gary_dexter
  • 30.44K
  • 1.88K
  • 4.04K
Message 2 of 16
Re: M200 slow speed
Try another cable?
  • 22.43K
  • 2.4K
  • 4K
Message 3 of 16
Re: M200 slow speed
Test on a known "good" ethernet cable (Cat5e/6) connected to a GB enabled computer/laptop, with up to date drivers with the Hub in modem mode. Test at speedtest.net to your nearest VM server - try 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown software, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
Anonymous
Not applicable
Message 4 of 16
Re: M200 slow speed
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
We can see if there is anything in the router stats that point to a localised problem.
Pmartin2
  • 8
Message 5 of 16
Re: M200 slow speed
Will do in the morning. Thanks.
I'll also get a new cable and test again.
Pmartin2
  • 8
Message 6 of 16
Re: M200 slow speed
Hi, i can't see the check router status tab,
I gave me no other option than to sign in. It just asked for the preferred language and then the password on the bottom of the router. No tabs on the page at all?
Pmartin2
  • 8
Message 7 of 16
Re: M200 slow speed
Just logged out and tried again and it has come up with a different login page with the router status tab 🤦‍♂️. I'll do it now.
Pmartin2
  • 8
Message 8 of 16
Re: M200 slow speed
Here you go.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
11387500006.537256 qam1
21467500006.137256 qam2
31547500006.937256 qam3
4162750000737256 qam4
51707500006.537256 qam5
61787500006.337256 qam6
71867500006.537256 qam7
81947500006.537256 qam8
92027500005.537256 qam9
102107500004.637256 qam10
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1462000544.675512064 qam2
2537002584.825512064 qam1
3326002584.45512064 qam4
4394001614.625512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Router status
Network LogTime Priority   Description
15/07/2020 08:25:47notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 20:27:54notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 20:27:8Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 06:25:21critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2020 18:11:34Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 22:30:16Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 01:32:11critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 22:19:1Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 06:33:58Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 05:23:42critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 14:48:57Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:26:10Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:26:10critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 23:24:54Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 15:01:34critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 15:01:29Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 15:01:29critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 15:01:21Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 01:52:41critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 30.44K
  • 1.88K
  • 4.04K
Message 9 of 16
Re: M200 slow speed
Can you post everything in the Downstream tab please?
That's only half the data posted
Pmartin2
  • 8
Message 10 of 16
Re: M200 slow speed
Sorry, here you go
Router status
11387500006.837256 qam1
21467500006.537256 qam2
3154750000737256 qam3
41627500007.337256 qam4
51707500006.637256 qam5
61787500006.537256 qam6
71867500006.637256 qam7
92027500005.837256 qam9
102107500004.837256 qam10
112187500004.537256 qam11
122267500004.637256 qam12
132347500004.837256 qam13
14242750000437256 qam14
152507500003.236256 qam15
162587500002.736256 qam16
172667500002.936256 qam17
18274750000336256 qam18
192827500002.936256 qam19
202907500002.536256 qam20
212987500002.436256 qam21
223067500002.236256 qam22
23314750000236256 qam23
243227500002.236256 qam24
1Locked37.65930
2Locked37.64490
3Locked37.32350
4Locked37.62180
5Locked37.3278460
6Locked37.62410
7Locked37.61910
8Locked37.61760
9Locked37.32070
10Locked37.32830
11Locked37.33040
12Locked37.32290
13Locked37.32320
14Locked373910
15Locked36.67100
16Locked36.67930
17Locked36.38570
18Locked36.67850
19Locked36.68980
20Locked36.39770
21Locked36.312580
22Locked36.614440
23Locked36.316080
24Locked36.314360
