JaniOliveira
  • 19
Message 1 of 23
M200 plan with Low Upload Speed - 5Mbps
Hello,
I have upgraded my M50 plan to M200 internet plan.
I'm experiencing slow upload speed at the moment, around 4.5 - 6 Mbps.
As stated on Virgin advertisement, should be around 20-21 Mbps.
I already did the factory reset on my Hub3 router and nothing changed.
I'm connected through cable and not Wi-Fi.
I think my upload is capped by my previous plan that was M50.
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 23
Re: M200 plan with Low Upload Speed - 5Mbps
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 23
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 23
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Nerog25
  • 9
Message 5 of 23
I am also having the same issue. Have tried rebooting and resetting as per the guides and I am getting 200Mbps Down, but only 2-3 Mbps up. I normally get 20Mbps up as you've mentioned.
Tags (3)
JaniOliveira
  • 19
Message 6 of 23
Here is the speed test result fromSamKnows and in my router the connection speed is 1000:
JaniOliveira
  • 19
Message 7 of 23
Downstream:
1387000000-3.540256 qam32
2219000000-0.740256 qam11
3227000000-238256 qam12
4235000000-240256 qam13
5243000000-1.940256 qam14
6251000000-340256 qam15
7259000000-240256 qam16
8267000000-2.440256 qam17
9275000000-2.740256 qam18
10283000000-2.540256 qam19
11291000000-2.740256 qam20
12299000000-3.540256 qam21
13307000000-3.240256 qam22
14315000000-3.738256 qam23
15323000000-4.738256 qam24
16331000000-3.440256 qam25
17339000000-4.538256 qam26
18347000000-438256 qam27
19355000000-340256 qam28
20363000000-4.440256 qam29
21371000000-340256 qam30
22379000000-338256 qam31
23395000000-3.240256 qam33
24403000000-3.938256 qam34
1Locked40.31790
2Locked40.31080
3Locked38.62560
4Locked40.33680
5Locked40.32030
6Locked40.32700
7Locked40.32390
8Locked40.32290
9Locked40.33720
10Locked40.33440
11Locked40.93210
12Locked40.96830
13Locked40.33020
14Locked38.95780
15Locked38.912320
16Locked40.34790
17Locked38.68750
18Locked38.95490
19Locked40.32060
20Locked40.39700
21Locked40.31670
22Locked38.91670
23Locked40.33990
24Locked38.92210
JaniOliveira
  • 19
Message 8 of 23
13939998548.5512064 qam8
25370025349.8512064 qam6
34620000049512064 qam7
46030025850.3512064 qam5
1ATDMA0010
2ATDMA0020
3ATDMA0020
4ATDMA0020
JaniOliveira
  • 19
Message 9 of 23
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID344502
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID344501
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
JaniOliveira
  • 19
Message 10 of 23
