JohnEpton
  • 31
Message 1 of 11
M200 download speed averages 60Mbps
I have a new M200 contract which claims to give me an average of 213Mbps.
i am lucky if I ever get 25% of that figure.
i an using various speed test packages on a Wired connection and checking several different Windows PCs.
i use a Hub 3.0 in Modem mode and a Netgear Nighthawk Router.
I am in BR6.
Can anyone help?
Aaron2
  • 869
  • 98
  • 162
Well-informed
Message 2 of 11
Re: M200 download speed averages 60Mbps
Try just using the Hub and no router, also which cable are you using & is your device actually 1Gbs capable?
** I work for VirginMedia but all opinions posted here are my own.
JohnEpton
  • 31
Message 3 of 11
Could you please explain how you can access the internet by just using the Hub as a Modem?
thanks
Andrew-G
  • 8.14K
  • 1.36K
  • 3.68K
Message 4 of 11
You would just restart your hub with the router disconnected, and then connect a single PC via ethernet.
But if you're struggling with speeds, I'd say just set temporarily set the hub to router mode, connect a PC via ethernet and see what speeds you then get - that's also how VM will want you to measure speed if you choose to invoke the minimum speed guarantee.  If in that configuration you see full speed, then there's a problem with the way that the Netgear is connected or configured.
As I recall, you had an over-utilisation problem?  If that's not been fixed, then potentially that's a cause or contributor to the speed problem.  The check for that is to do a speed test early in the morning, say before 7 am.  If that gets 200 Mbps, but then it gets worse during the day, and is particularly poor late afternoon and evening, chances are that the speeds are down to over-utilisation.
JohnEpton
  • 31
Message 5 of 11
Thanks for everyone’s help. My problem is solved and the solution may be of help to others.
I was getting about 60 Mbps on my Ethernet connected laptop. Connecting the laptop to my modem directly, with help from the forum, I got around 200 Mbps. Then realised that my network had two old Ethernet switches between the router and the laptop. These have a max speed of 100 Mbps. So I replaced these with I Gbps switches. I also reconfigured all my network interface cards to default to 1 GBPs.
I now get between 150 and 200 Mbps on all my PCs.
Thank you all
JohnEpton
  • 31
Message 6 of 11
Please let me have your thoughts on this horrific graph.
  • 26.4K
  • 2.69K
  • 4.89K
Message 7 of 11
That looks like a case of over utilisation during "peak hours" - i.e. too many customers connected. Others may want to comment
Are you experiencing connection problems - if so when did they start
JohnEpton
  • 31
Message 8 of 11
My connections problems have existed for at least 12 months. So bad that I had to ditch my previous VOIP phone.
How do I get VM to do something about it?
  • 26.4K
  • 2.69K
  • 4.89K
Message 9 of 11
If it "is" overutilisation I would refer you to the comments from @Andrew-G here....
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 11
Nicked.
