topaul13
  • 16
Message 1 of 17
M200 customer Max download speeds Very low
I have a Hub 3, previously the 2 and I have to say I had no issues with that model but I have followed all the instructions given to me. Rebooted, replaced, check connections and nothing is improving my download speeds.
What do I need to do because I have run out of ideas.
See below for speeds I took at 21:00
Cheers in advance
Anonymous
Not applicable
Message 2 of 17
Re: M200 customer Max download speeds Very low
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
topaul13
  • 16
Message 3 of 17
Direct link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/95ac13c930e112faae6eb0bc94e051e206c4b97d
topaul13
  • 16
Message 4 of 17
Downstream Settings
1331000000-140256 qam25
2267000000040256 qam17
3275000000040256 qam18
4283000000040256 qam19
5291000000040256 qam20
6299000000040256 qam21
7307000000040256 qam22
8315000000-0.240256 qam23
9323000000-0.740256 qam24
10371000000-1.540256 qam26
11379000000-1.440256 qam27
12387000000-1.440256 qam28
13395000000-1.440256 qam29
14403000000-1.440256 qam30
15411000000-1.240256 qam31
16419000000-140256 qam32
17427000000-140256 qam33
18435000000-140256 qam34
19443000000-0.740256 qam35
20451000000-0.740256 qam36
21459000000-0.940256 qam37
22467000000-1.440256 qam38
23475000000-240256 qam39
24483000000-2.240256 qam40
1Locked40.3120
2Locked40.960
3Locked40.350
4Locked40.360
5Locked40.940
6Locked40.950
7Locked40.950
8Locked40.360
9Locked40.300
10Locked40.360
11Locked40.9120
12Locked40.340
13Locked40.350
14Locked40.360
15Locked40.350
16Locked40.360
17Locked40.350
18Locked40.930
19Locked40.960
20Locked40.950
21Locked40.350
22Locked40.950
23Locked40.360
24Locked40.340
Tags (1)
topaul13
  • 16
Message 5 of 17
1602999884.625512064 qam9
2394000394.275512064 qam12
3461999354.375512064 qam11
4536999574.625512064 qam10
3ATDMA0000
4ATDMA0000
Tags (1)
topaul13
  • 16
Message 6 of 17
4/10/2020 20:26:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 20:24:53Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 14:30:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:28:21noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:28:21ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 11:37:12ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 11:25:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 07:50:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 10:09:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 19:13:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 19:13:13ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 09:08:52ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2020 23:46:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2020 23:04:36ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 22:23:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 21:13:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 21:13:20ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 17:20:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 15:03:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 14:14:28ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
topaul13
  • 16
Message 7 of 17
Anonymous
Not applicable
Message 8 of 17
Ok, your HUB stats actually look ok, however the BQM doesn't look great.
We'll need to leave it to mature for a while to see the full picture.
topaul13
  • 16
Message 9 of 17
Great thanks 👍
topaul13
  • 16
Message 10 of 17
 thats  at the time of 17.08.
