chopper67
  • 22
Message 1 of 33
M200 broadband download seed only reaching 10mbs max
M200 service speed used to be good (100mbs or more) but last few weeks much slower. Download never better than around 10mbs with upload 20mbs
Have reset router, tried hard-wired devices to rule out WiFi issues, have run VM checks which come back reporting no issue. There is also no faults on the VM status in my area
Looking in the HUB 3 router status, all of the the 24 downstream bonded channels have lots of Pre RS and Post RS errors, so not sure if this is pointing to the issues
Is anyone able to offer any assistance please?
DJ_Shadow1966
  • 6.88K
  • 1.32K
  • 1.9K
Message 2 of 33
Re: M200 broadband download seed only reaching 10mbs max
Hello
Lots of Post RS errors tend to be an issue with noise, can you please go around and make sure that all coaxial connections are finger tight, best way is too loosen then and re-tighten them, then power off hub for 30 secs and then back on.
If your post RS errors keep rising at a large rate can you post the downstream, upstream and network logs here and the community can have  a look.
Regards  Mike
chopper67
  • 22
Message 3 of 33
Checking now...
Thanks for the super fast response
chopper67
  • 22
Message 4 of 33
Hi Mike
After doing what you suggested, the Post RS errors are now at zero and Pre RS errors in single digits. This is after 10 mins of uptime / use. Download speed is back to the 160 - 180 mbps rate
Thank you so much for helping me out
Neal
DJ_Shadow1966
  • 6.88K
  • 1.32K
  • 1.9K
Message 5 of 33
Hello
Excellent keep an eye on it and if the problem reoccurs the by all means post back in this thread.
Regards Mike
chopper67
  • 22
Message 6 of 33
Will do Mike
Thanks once again, really appreciate your help
Neal
chopper67
  • 22
Message 7 of 33
Disappointingly, the slow speed issue has returned
10.6 mbs on a 200mbs service
The post RS errors have not returned but the pre RS errors are increasing
Below are the screen shots. Is anyone able to advise on next steps please?
chopper67
  • 22
Message 8 of 33
1 299000000 -0.7 38 256 qam 21
2 139000000 0.2 37 256 qam 1
3 147000000 0 38 256 qam 2
4 155000000 0 38 256 qam 3
5 163000000 0 38 256 qam 4
6 171000000 -0.2 38 256 qam 5
7 179000000 -0.4 38 256 qam 6
8 187000000 -0.2 38 256 qam 7
9 195000000 -0.4 38 256 qam 8
10 203000000 -0.5 38 256 qam 9
11 211000000 -0.7 38 256 qam 10
12 219000000 -0.5 38 256 qam 11
13 227000000 -0.7 38 256 qam 12
14 235000000 -0.7 38 256 qam 13
15 243000000 -0.9 38 256 qam 14
16 251000000 -0.9 38 256 qam 15
17 259000000 -0.9 38 256 qam 16
18 267000000 -1.2 38 256 qam 17
19 275000000 -1.2 38 256 qam 18
20 283000000 -0.9 38 256 qam 19
21 291000000 -0.9 38 256 qam 20
22 307000000 -1.2 38 256 qam 22
23 315000000 -1.2 38 256 qam 23
24 323000000 -1.2 38 256 qam 24
chopper67
  • 22
Message 9 of 33
1 Locked 38.9 664 0
2 Locked 37.6 1015 0
3 Locked 38.6 226 0
4 Locked 38.6 154 0
5 Locked 38.6 129 0
6 Locked 38.6 1365 0
7 Locked 38.6 2557 0
8 Locked 38.6 2022 0
9 Locked 38.6 403 0
10 Locked 38.9 45 0
11 Locked 38.6 59 0
12 Locked 38.6 109 0
13 Locked 38.6 60 0
14 Locked 38.6 43 0
15 Locked 38.6 309 0
16 Locked 38.9 1398 0
17 Locked 38.9 965 0
18 Locked 38.9 180 0
19 Locked 38.9 140 0
20 Locked 38.6 245 0
21 Locked 38.9 302 0
22 Locked 38.9 523 0
23 Locked 38.6 573 0
24 Locked 38.9 644 0
chopper67
  • 22
Message 10 of 33
1 46200034 4.7 5120 64 qam 11
2 39400017 4.55 5120 64 qam 12
3 53700000 4.7 5120 64 qam 10
4 60299964 4.7 5120 64 qam 9
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
