SViruS83
Message 1 of 5
M200 Slow Upload speed
For last several days I'm experiencing slow upload speed. It is in range 1.2Mbps-2.5Mbps . With 200Mbps connection I'm expecting about 20Mbps.
I'm runing speed tests both on Wi-Fi and Ethernet connection and result is the same. And obviously exuipment been reseted between tests and it make no difference.
Heres required data from Hub 3.0
1187000000-0.238256 qam7
2139000000-0.438256 qam1
3147000000-0.538256 qam2
4155000000-0.738256 qam3
5163000000-0.538256 qam4
6171000000-0.238256 qam5
7179000000-0.238256 qam6
8195000000-0.238256 qam8
9203000000038256 qam9
10211000000-0.238256 qam10
11219000000-0.238256 qam11
12227000000-0.438256 qam12
13235000000-0.438256 qam13
14243000000-0.538256 qam14
15251000000-0.738256 qam15
16259000000-0.938256 qam16
17267000000-138256 qam17
18275000000-1.238256 qam18
19283000000-1.238256 qam19
20291000000-1.238256 qam20
21299000000-1.238256 qam21
22307000000-1.238256 qam22
23315000000-138256 qam23
24323000000-0.938256 qam24
1Locked38.950
2Locked38.650
3Locked38.960
4Locked38.960
5Locked38.990
6Locked38.950
7Locked38.950
8Locked38.960
9Locked38.960
10Locked38.960
11Locked38.950
12Locked38.990
13Locked38.950
14Locked38.670
15Locked38.690
16Locked38.960
17Locked38.970
18Locked38.980
19Locked38.650
20Locked38.670
21Locked38.670
22Locked38.960
23Locked38.930
24Locked38.980
1537000003.846512016 qam10
2393998613.725512016 qam12
3462001613.775512016 qam11
4603000003.7512016 qam9
3ATDMA0000
4ATDMA0000
25/09/2020 14:55:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 14:54:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 14:53:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 14:53:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 14:53:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:42:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:41:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:41:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:41:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:37:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:37:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:36:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:36:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 15:36:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 2 of 5
Re: M200 Slow Upload speed
Your upstream channels are out of spec, which explains the slow upload speed:
The highlighted values should be 64 QAM.
SViruS83
Message 3 of 5
Thank You for that information.
Now the question is - what can I do about it?
Anonymous
Not applicable
Message 4 of 5
Wait for a VM staff member to reply to your thread, or contact VM directly.
SViruS83
Message 5 of 5
Thank You
