DeadCell79
  • 9
Message 1 of 10
M200 Slow Speed. 39mbs / 42mbs for the past 2 weeks (should be on 200Mbps)
Hello. so its been around 2 weeks maybe more as the last time i did a speed test was on the 14th of November and my speeds have been consistently around the 40MBS, and that's on my NEW PC and all the mobile devices in the house. I am 100% certain it is not my devices
I'm on M200 and normally hit around 200Mbs. I've done all the trouble shooting tips that typically tell us on the website from resetting the router to checking all the cables are connected correctly. They never get touched so i don't see why they would be an issue but i checked them anyway just to be sure. i am also using a Super Hub 2ac since it was launched to replace the first super hub i had.
I also did a service test/check online and this what it showed. i have uploaded an image.
service checkedservice checked
In case the image didn't upload above. this is what the following says:
(!) Network Issue
There's a network issue which maybe affecting your broadband service
What does this mean?
-This issue caused by interference on the cabling coming into your home.
-This will cause intermittent speeds and performance my vary
PhilRenoir
Message 2 of 10
Re: M200 Slow Speed. 39mbs / 42mbs for the past 2 weeks (should be on 200Mbps)
I am getting the exact same problem. I am on the 200mbps package. For the past 3 weeks i have not been getting past 25 - 30mbps, with pings of around 18 -20ms.  As i have one of the new Hub4 boxes i can not do a quick self test on line as they havent come up with the ability to do that yet (!).
I am working from home which is making this really difficult. Needs to be sorted soon, if not NOW!
neilclarke
  • 12
Message 3 of 10
i get the same, but am on m500 package.  it is really shocking.  turned everything off except the PC checking it and can just scrape 50mbps download.  however upload is 36mbps which is best i have seen and consistent at that level all the time.
i start a wfh job Thursday and urgently need reliable broadband.
DeadCell79
  • 9
Message 4 of 10
I'm glad i ain't the only one because this issue. as its highly irritating considering how many of us are now working from home. i get that the service might be put under strain but how much can we expect to keep believing that the service having issues is all down to the knock on effects of the pandemic.
if that is the case then the service was never good enough in the first place to handle. i find that hard to believe, especially if more than myself is experiencing lower speeds.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 10
(!) Network Issue
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
DeadCell79
  • 9
Message 8 of 10
My BQM
DeadCell79
  • 9
Message 9 of 10
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000155000000163000000N/A179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedUnlockedLockedLockedLocked
Channel ID1234N/A678
Modulation256QAM256QAM256QAM256QAMUnknown256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.952000N/A6.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
N/AI=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)3.673.533.273.06N/A2.392.202.15
RxMER (dB)37.3637.9437.3637.64N/A37.9437.9437.64
Pre RS Errors
9395534407367N/A296295312
Post RS Errors
285299290305N/A294295310
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID3654
Frequency (Hz)46200000258000003260000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)40.0038.5040.0040.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID76
Max Traffic Rate230000061 bps
Max Traffic Burst42600 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID75
Max Traffic Rate22000061 bps
Max Concatenated Burst42600 bytes
Scheduling TypeBest Effort
First TimeLast TimePriorityError NumberDescription
30/11/2020 13:16:58 GMT30/11/2020 13:16:58 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedError (4)68000406TOD server unavailable
Corey_C
  • 4.78K
  • 243
  • 398
Message 10 of 10
Hi DeadCell79, neilclarke and PhilRenoir
Thanks for your post and for reaching out to community forums. Sorry to hear that you have been having internet issues and for the delayed response. I've sent you each private messages for further diagnostics and to confirm your account details.
Cheers,
Corey C
