mikewilson3run
Settling in
M200 Package | Upload Speed is Faster than Download
Hi all, hoping someone could shed some light on my problem. I'm a new Virgin Media customer and just bought the M200 package. I've installed the hub exactly as the instructions require. I found a happy home for the hub and rebooted as requested. Ive done a speed test and this definitely doesn't look right. I've attached a picture showing my download speed is less than 20mb and slower than my upload speed.
We are Area 31.
I've used the approved speed tester and this was my results.
Can anyone help?
gary_dexter
  • 30.38K
  • 1.88K
  • 4.04K
Re: M200 Package | Upload Speed is Faster than Download
Are you using a wired or wireless connection?
mikewilson3run
Settling in
When mi tested it was Wireless. However i just checked with a wired connection and i was getting nearly 200mb download and 20mg upload so that seems fine.
But surely i should be getting faster speeds for wireless?
Thanks for your response.
gary_dexter
  • 30.38K
  • 1.88K
  • 4.04K
No - wifi speeds are not guaratneed and any number of factors can effect them.
Have you tried splitting and renaming the WiFi bands, disabling "Smart" WiFi, checking for less congested channels etc?
mikewilson3run
Settling in
Can you direct me how i would split it?
Eeeps
  • 753
  • 47
  • 118
Rising star
You don't say what device you are performing the test on or your distance from the SH3.
Does the speed vary with distance?
At least your wired speeds are good which means that you will be able to get good WiFi speeds even if you have to resort to buying some additional WiFi kit.
But before you put your hand in your pocket there are some adjustments that can be made to your router WiFi settings to get the best out of it.
There is a sticky thread at the top of the 'Networking and WiFi' forum that may help with this.
