leedanskin
  • 7
Message 1 of 8
M200 - M500 but not full speed increase
Hi There
So got my upgrade from M200 to M500 at the weekend, but only seeing a 300-350Mb speed as if its M350, the system is in modem mode with a cat6 cable and 1Gb network capability, am i being impatient or should it be fairly instant ?
Usual modem configs look ok? So wondered how I got the other end checked out?
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
5.4
40
256 qam
9
2
211000000
5.1
38
256 qam
10
3
219000000
4.5
40
256 qam
11
4
227000000
4.3
38
256 qam
12
5
235000000
3.9
38
256 qam
13
6
243000000
3.5
38
256 qam
14
7
251000000
3.2
40
256 qam
15
8
259000000
3.2
38
256 qam
16
9
267000000
3.2
38
256 qam
17
10
275000000
3.2
38
256 qam
18
11
283000000
3.4
40
256 qam
19
12
291000000
3.2
38
256 qam
20
13
299000000
3
38
256 qam
21
14
307000000
2.9
40
256 qam
22
15
315000000
3
40
256 qam
23
16
323000000
3.2
40
256 qam
24
17
427000000
1.2
40
256 qam
25
18
435000000
0.7
38
256 qam
26
19
443000000
0.4
38
256 qam
27
20
451000000
0.4
38
256 qam
28
21
459000000
0.2
38
256 qam
29
22
467000000
0
38
256 qam
30
23
475000000
0
40
256 qam
31
24
483000000
-0.2
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
5
0
2
Locked
38.9
5
0
3
Locked
40.3
2
0
4
Locked
38.9
6
0
5
Locked
38.9
6
0
6
Locked
38.6
6
0
7
Locked
40.3
7
0
8
Locked
38.9
8
0
9
Locked
38.9
9
0
10
Locked
38.9
8
0
11
Locked
40.3
12
0
12
Locked
38.9
8
0
13
Locked
38.6
9
0
14
Locked
40.3
11
0
15
Locked
40.3
21
0
16
Locked
40.3
6
0
17
Locked
40.3
29
0
18
Locked
38.9
32
0
19
Locked
38.9
35
0
20
Locked
38.9
33
0
21
Locked
38.9
37
0
22
Locked
38.9
60
0
23
Locked
40.3
54
0
24
Locked
38.9
61
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700010
41.3
5120
64 qam
6
2
46200000
40.8
5120
64 qam
7
3
39400000
40.3
5120
64 qam
8
4
60300000
42
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 3.2K
  • 249
  • 695
Message 2 of 8
Re: M200 - M500 but not full speed increase
You need to post your configuration details. Once you get the correct configuration file the speed boost applied right away.
leedanskin
  • 7
Message 3 of 8
Ok then i think the config is correct as well but still not getting full 500 ?   General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID139528
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID139527
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Anonymous
Not applicable
Message 4 of 8
The only 'odd' thing with your stats is the large difference between your downstream channel power levels.
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
leedanskin
  • 7
Message 5 of 8
https://www.thinkbroadband.com/broadband/monitoring/quality/share/99f971713fc0becd8d32577ecc1077b941e7337c
is the live link
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
Carl is correct.
The differential between the lowest Downstream Power Level at -0.2dBmV and the highest at +5.4dBmV is far too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
leedanskin
  • 7
Message 7 of 8
Thanks chaps will have a chat with the engineers first thing!
Lee
leedanskin
  • 7
Message 8 of 8
Ok so was hoping that i did not have too go this route but hey,
So after phoning first thing, i chat to a very helpful lady who makes me do all the checks and jumps.
Put it modem mode, boot windows into safe mode, use a cat6 cable all the checks ( I have been doing IT for 30+ years ) highly funny
Putting you though to the engineering team on hold she states that she will sort it etc...
Double check today and get the notification that the minimum guaranteed speed speech is....
  Download Speeds Upload Speeds
ProductAdvertised Speed*Expected Speed Range**Minimum Guaranteed Download Speed Advertised Speed*Expected Speed Range**
M5054 Mbps52 - 54 Mbps27 Mbps5 Mbps5 Mbps
M100108 Mbps108 - 111 Mbps54 Mbps10 Mbps10 Mbps
M200213 Mbps211 - 218 Mbps107 Mbps20 Mbps20 - 21 Mbps
M350362 Mbps360 - 384 Mbps181 Mbps36 Mbps35 - 37 Mbps
M500516 Mbps480 - 543 Mbps Mbps36 Mbps35 - 37 Mbps
M600636 Mbps565 - 654 Mbps318 Mbps41 Mbps41 - 42 Mbps
Gig1 Fibre Broadband1140 Mbps1127 - 1145 Mbps570 Mbps52 Mbps51 - 52 Mbps
I was hoping to upgrade to M600 package I work from home and have 2 uni students who will be streaming all their lectures so thought great idea!
Now to be told that no engineer and suck it up when i have obviously an issue on the cable installation and would like to just get the best performance possible!
I have been polite and not shouted but to be told that my M500 package delivers less than M350 package is pretty disgusting, if anybody from virgin is monitoring this then please contact me to resolve this. First agent was great and helpful, second was the worlds worst agent who had been trained to just argue the toss with the customer expected range is 480-543 happy with any of that and in extreme instances i can understand it might be a bad day and slow to the worst 258 but to be blanket told that i cannot have an engineer is ridculous!
love virgin been great but some of your agents need training! I run a help desk!
