BigD289
  • 14
M200 Half speed and packet loss
I've just switched to M200 and I only seem to be getting M100 speeds.
I'm testing on a Unifi Dream Machine directly connected to the VM modem via Gigabit.
I also am getting dropped packets. I can see I am getting a lot of Post RS errors on one channel.
I've spoken to VM but I'm not getting any sensible responses. Does anyone know how I can get this fixed?
Modem logs below:
Cable Modem Status
Item Status Comments
203000000
Locked
Ranged Upstream Channel (Hz)
60300087
Locked
Provisioning State
Online
12030000002.738256 qam9
22110000002.538256 qam10
32270000002.525256 qam12
4235000000337256 qam13
52430000002.538256 qam14
6251000000238256 qam15
72590000002.738256 qam16
82670000002.538256 qam17
92750000002.738256 qam18
102830000002.238256 qam19
112910000002.537256 qam20
122990000002.938256 qam21
13307000000238256 qam22
143150000002.738256 qam23
153230000002.438256 qam24
163310000002.938256 qam25
173390000002.237256 qam26
18347000000238256 qam27
193550000002.738256 qam28
203630000002.538256 qam29
213710000002.538256 qam30
223790000002.238256 qam31
233870000002.438256 qam32
1Locked38.616980
2Locked38.620044
3Locked25.12900557500683898
4Locked37.620250
5Locked38.618230
6Locked38.68270
7Locked38.6800
8Locked38.9760
9Locked38.62140
10Locked38.61200
11Locked37.61000
12Locked38.6440
13Locked38.6770
14Locked38.6320
15Locked38.91220
16Locked38.9630
17Locked37.660
18Locked38.9180
19Locked38.6110
20Locked38.9120
21Locked38.9110
22Locked38.980
23Locked38.9120
16030008749.5512064 qam1
23940000048.5512064 qam4
35369998549.8512064 qam2
44619999648.3512064 qam3
3ATDMA0000
4ATDMA0000
BigD289
  • 14
Re: M200 Half speed and packet loss
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID327406
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID327405
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
04/11/2021 17:31:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 17:31:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 17:31:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 17:31:45Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 15:44:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 15:44:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 14:40:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 14:40:54Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 13:39:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 13:39:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:46:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:46:44Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:46:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:46:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:45:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 12:45:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 11:44:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 11:44:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 09:52:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2021 09:52:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 10.42K
  • 1.66K
  • 4.76K
I've marked for staff to take a look, but you're right there's a specific problem (noise ingress) on downstream channel 3, and given the 227 MHz frequency, the source of the signal is almost certainly DAB radio broadcasting.  That might require a technician visit, but I suggest you disconnect and carefully remake all coax cable connections in the house, with any securing nuts done up finger tight.  If there is one, and you're confident to do so, pop open the brown box on the outside wall and do the same for any coax connections in there.  If there's physical damage to the coax anywhere, or you're using third party cable you bought yourself, then those are other possible causes.
Restarting the hub (or it re-registering after you undo and remake any connections) will take the usual 7 minutes, and that alone might provide temporary relief if the hub doesn't select 227 MHz or a very close frequency, but until the point of ingress is fixed, you will find the problem returns.
BigD289
  • 14
Thanks for the reply. I've reset the modem and unplugged/replugged the cables.
The cables are new (installed 4 days ago) and relatively short.
Still loads of errors on reboot.
I've given VM a call. They say I need to wait 24 hours before they will do anything 😞
Seems to be getting worse now, only getting 30 Mbps and significant packet loss witch is really affecting Teams calls.
1Locked38.950
2Locked38.660
3Locked26.9264125914511297
4Locked37.300
5Locked38.650
6Locked38.600
7Locked38.960
8Locked38.640
9Locked38.900
10Locked38.650
11Locked38.600
12Locked38.900
13Locked38.600
14Locked38.950
15Locked38.950
16Locked38.960
17Locked37.350
18Locked38.900
19Locked38.600
20Locked38.640
21Locked38.900
22Locked38.950
23Locked38.900
John_GS
  • 14.41K
  • 737
  • 1.34K
Hi BigD289
Thanks for posting. Apologies for the broadband issue. I'll send you a PM now as we will need to get a tech out.
Best,
John_GS
John_GS
  • 14.41K
  • 737
  • 1.34K
Thanks for joining me on PM @BigD289
Just to update the thread, engineer visit booked in.
This can be tracked in your online account
Let us know how the visit goes.
Best,
John_GS
