felixnewman
  • 6
M200 Fibre Broadband - Consistent <100mbps speed
M200 Fibre Broadband based in SW London
Broadband has been tested both using the Hub in Router mode and in Modem mode. When in Modem mode the connection is via an Asus RT-AC68U router
At all times I am testing over Cat6 Ethernet, never Wi-Fi.
Average speed test from Ookla and other test providers are:
Download -  92 Mbps
Upload  - 19 Mbps
Ping - 9ms
Copy from Network Logs.
11950000002.538256 qam8
21390000003.538256 qam1
31470000003.240256 qam2
4155000000338256 qam3
51630000002.538256 qam4
61710000002.238256 qam5
7179000000238256 qam6
81870000002.438256 qam7
92030000002.540256 qam9
102110000002.738256 qam10
11219000000338256 qam11
122270000003.438256 qam12
132350000003.538256 qam13
142430000003.438256 qam14
152510000003.538256 qam15
162590000003.538256 qam16
172670000003.938256 qam17
182750000003.938256 qam18
19283000000438256 qam19
20291000000438256 qam20
212990000004.138256 qam21
22307000000438256 qam22
233150000003.938256 qam23
243230000003.538256 qam24
1Locked38.950
2Locked38.650
3Locked40.350
4Locked38.960
5Locked38.970
6Locked38.900
7Locked38.950
8Locked38.940
9Locked40.350
10Locked38.9130
11Locked38.950
12Locked38.960
13Locked38.640
14Locked38.960
15Locked38.630
16Locked38.960
17Locked38.940
18Locked38.950
19Locked38.960
20Locked38.970
21Locked38.650
22Locked38.950
23Locked38.960
24Locked38.950
13260000043512064 qam13
23940000943512064 qam12
34619998344.5512064 qam11
45370001445.5512064 qam10
3ATDMA0000
4ATDMA0000
Tags (3)
felixnewman
  • 6
Re: M200 Fibre Broadband - Consistent <100mbps speed
15/11/2020 16:02:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 15:20:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 15:20:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 22:13:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:47:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:47:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:17:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 13:17:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:47:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:47:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:17:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 12:17:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:47:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:47:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:17:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:17:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 10:47:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 10:47:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 10:17:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt044-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you set up the test machine using an ethernet cable direct to the Hub and with the Hub in Router Mode.
Then Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
felixnewman
  • 6
Interesting stuff. So straight into the Hub (both in Router Mode and via Asus Router with Hub in Modem Mode) is 1Gbps, whereas through the cabling in the wall it is 100 Mbps.
Flow currently is Hub in Modem Mode -> Cat6 Cable (Confirmed 1Gbps) -> Asus Router -> Cat6 RJ45 Male connector to Female wall outlet -> Cat6 Cable to test device.
Am I missing a switch in here somewhere to keep the speeds at 1Gbps?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
You said "cable through the wall".
Is that straight out of the Hub to the test device ?
felixnewman
  • 6
This was really helpful stuff. Made me look again at the Cat6 setup and ended up redoing the wiring completely which fixed the 100Mbps problem and has boosted speeds up to where they should be.
Thanks!
