lpking2005
  • 6
Message 1 of 11
M200 Broadband speed all over the place
Ive been a customer for a very long time and i know that the speeds have always been a bit random but lately they have been all over the place.
Im on the M200 package and lately ive been averaging anywhere from 20mbps to around 105mbps.
I'm currently still using a Superhub 2 if this is of any significance. Although an engineer last year told me to not request the superhub 3 because the performance was terrible.
Any help would be really appreciated!
Current log:
lpking2005
  • 6
Message 2 of 11
Re: M200 Broadband speed all over the place
Copy and paste would of been easier! 😉
DOWNSTREAM:
Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked1138750000 Hz256 QAM-1.7 dBmV37.6 dB315284
Locked2146750000 Hz256 QAM-1.3 dBmV37.9 dB286272
Locked3154750000 Hz256 QAM-1.1 dBmV37.9 dB275270
Locked4162750000 Hz256 QAM-1.3 dBmV37.9 dB285282
Locked5170750000 Hz256 QAM-1.6 dBmV37.9 dB302291
Locked6178750000 Hz256 QAM-1.2 dBmV38.3 dB295295
Locked7186750000 Hz256 QAM-1.0 dBmV38.3 dB303303
Locked8194750000 Hz256 QAM-1.0 dBmV38.3 dB292292
Anonymous
Not applicable
Message 3 of 11
Could you post the upstream data?
lpking2005
  • 6
Message 4 of 11
UPSTREAM:
US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID2134
Frequency (Hz)39400000462000003260000025800000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)48.0048.2547.5046.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 11
lpking2005
  • 6
Message 6 of 11
I have created a monitor and will report back when i have some data.
Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 11
Just post the link now and we can watch it develop or advise if there is a problem with it.
lpking2005
  • 6
Message 8 of 11
My BQM
  • 15.9K
  • 687
  • 1.56K
Message 9 of 11
You need to enable ping on the hub.
Anonymous
Not applicable
Message 10 of 11
I think it's working!
