sosullivan
  • 9
Message 1 of 13
M100 - very poor speed
Hi folks,
I'm on M100 and my speed tests show around 32 Mbits and 10 Mbits respectively.
I attach the text from my Router status here and would be grateful if somebody could give me some advice please.
Seamus
Cable Modem Status
Item
Status
Comments
235000000
Locked
Ranged Upstream Channel (Hz)
46200048
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
235000000
1
37
256 qam
13
2
139000000
3.9
37
256 qam
1
3
147000000
3.7
37
256 qam
2
4
155000000
3.7
37
256 qam
3
5
163000000
3.5
37
256 qam
4
6
171000000
3.5
37
256 qam
5
7
179000000
3.2
37
256 qam
6
8
187000000
3
37
256 qam
7
9
195000000
2.5
37
256 qam
8
10
203000000
2.2
37
256 qam
9
11
211000000
1.7
37
256 qam
10
12
219000000
1.5
37
256 qam
11
13
227000000
1.2
37
256 qam
12
14
243000000
0.5
37
256 qam
14
15
251000000
0
37
256 qam
15
16
259000000
-0.2
37
256 qam
16
17
267000000
-0.2
37
256 qam
17
18
275000000
0.2
37
256 qam
18
19
283000000
0.5
37
256 qam
19
20
291000000
0.5
37
256 qam
20
21
299000000
0.7
37
256 qam
21
22
307000000
0.5
37
256 qam
22
23
315000000
0.5
37
256 qam
23
24
323000000
0.4
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
59
16
2
Locked
37.3
136
0
3
Locked
37.3
140
0
4
Locked
37.6
126
0
5
Locked
37.3
124
0
6
Locked
37.6
107
0
7
Locked
37.6
126
14
8
Locked
37.3
89
0
9
Locked
37.6
92
0
10
Locked
37.6
81
0
11
Locked
37.3
68
13
12
Locked
37.6
59
0
13
Locked
37.3
64
1
14
Locked
37.6
75
0
15
Locked
37.3
85
0
16
Locked
37.6
71
0
17
Locked
37.3
75
0
18
Locked
37.6
47
0
19
Locked
37.6
50
0
20
Locked
37.6
47
0
21
Locked
37.6
37
0
22
Locked
37.6
33
0
23
Locked
37.3
30
0
24
Locked
37.6
42
0
************************************************************************* Upstream bonded channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200048
4.2
5120
64 qam
3
2
60300058
4.2
5120
64 qam
1
3
39399993
4.05
5120
64 qam
4
4
53700034
4.2
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
kldJKDHSUBsgvca69834ncxv98732
SFID
850
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
849
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 13
Re: M100 - very poor speed
I take it you are connecting over Wi-Fi ?
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
sosullivan
  • 9
Message 3 of 13
Hi Mike,
Indeed I was connected via WiFi.
I connected by cable and the speeds were:
101.4 and 9.67
Cheers
Seamus
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 13
IP provided Hubs are renowned for their poor Wi-Fi, and at the best of times Wi-Fi is a fickle beast that can be affected by numerous things such as distance from the Hub,  building construction, other electronic devices, neighbouring Wi-Fi, basically all sorts.
VM supply to the Hub, after the Hub it is up to you.
Many on here, myself included advocate the use of a third party Gigabit capable Wi-Fi router or Mesh system.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 13
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
John_GS
  • 8.7K
  • 476
  • 769
Message 6 of 13
Hi sosullivan
Thanks for posting.
My apologies for the lower than expected speeds.
I've ran a check on the system and no issues are showing. There is however one device showing as too close to the router. Could this be connected via Ethernet, or moved away from the router, as this is potentially limiting the bandwidth.
Kind regards,
John_GS
sosullivan
  • 9
Message 7 of 13
Thanks John,
Are you able to tell what that one device is? I only have TIVO box and a raspberry pi both ethernet connected.
Seamus
John_GS
  • 8.7K
  • 476
  • 769
Message 8 of 13
Hi Seamus,
Is there anything else close to the router that's connected wireless, like any streaming devices etc?
Kind regards,
John_GS
sosullivan
  • 9
Message 9 of 13
Hi there,
Yes I have a Chromecast plugged in to HDMI and connected wirelessly.
Hopefully that's not going to be the cause of slow speed?
Seamus
sosullivan
  • 9
Message 10 of 13
Hi John,
So I'm using a raspberry pi set up with pihole to stop ads. I've switched off DHCP in the Superhub and switched it on in the pi.
Nothing else out of the ordinary
Seamus
