HowieH
  • 8
Message 1 of 11
M100 upload speed
Every since Virgin carried out planned maintenance work in the WN7 area of Greater Manchester on 18th August, my upload speed has halved (from close to 10 Mb/s down to nearly 5 Mb/s). Why is this? I'm on the M100 service.
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 11
Re: M100 upload speed
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
HowieH
  • 8
Message 3 of 11
Upload speeds now back to normal for the last couple of days. Assume there was some issue following the planned maintenance and this has been resolved.
HowieH
  • 8
Message 4 of 11
Spoke too soon. Lost broadband and TV for around 17 hours. I don't see how the network maintenance of last week has done anything to keep broadband working well, if anything it's made it much worse.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 5 of 11
How about posting the information requested in Post #2 of this thread ?
HowieH
  • 8
Message 6 of 11
Because it became clear that the fault was on the network rather than anything to do with my connection to the street level cabinet. Pretty much every issue I've ever seen has been network related where Virgin engineers have to rebalance the loads to even out bandwidth. I pay for a service where Virgin Media diagnose and resolve faults on my behalf. As for your suggestions, I can't link an Ethernet cable to my smartphone for the exercise you're suggesting. I went to the site you named and tried to initiate a monitor but I don't understand what I'm supposed to be looking for. I was under the impression that this website was monitored by Virgin Media support staff who could investigate problems on my behalf. I'm not going to devote hours to troubleshoot problems when it's not my responsibility to do so. Once I saw the upload speeds recover I assumed the post maintenance fault had been resolved until I lost both broadband and TV for about 17 hours. As you might imagine I'm pretty p****d off with Virgin right now.
Melissa_F
  • 2.72K
  • 158
  • 215
Moderator
Moderator
Message 7 of 11
Hi HowieH,
Thanks for your post.
I'm really sorry that you've been having ongoing broadband problems and I can see why you'd be frustrated with this.
I've had a look at your services and your power levels are out of specification so I've booked you a technician appointment.
I've booked you in for the next available slot and you can see the details of this via your online account here
You can rearrange the appointment there also if this isn't suitable.
Melissa
HowieH
  • 8
Message 8 of 11
Hi Melissa
I responded to an SMS text asking me about the technician visit by saying FIXED before I saw your posting here (the email alerting me to the forum update ended up in my spam folder).
Upload speeds are close to 10Mbps now so that looks okay to me following the network outage. I've occasionally clocked downloads using the Speedtest app on my phone reaching 100Mbps but that's rare and I'm usually on 50Mbps max.
Do I still need to get a technician here? I've always assumed that I get the 50Mbps download speed because of bandwidth contention and lack of capacity on the fibre backbone.
Melissa_F
  • 2.72K
  • 158
  • 215
Moderator
Moderator
Message 9 of 11
Hi HowieH,
I'm glad things are looking better, but yes you'll still need a technician appointment as your power levels are out of spec so I'd like to get that fixed for you.
The appointment is still showing on your account at the moment. Have you had a reply from the text?
Melissa
HowieH
  • 8
Message 10 of 11
I got a text reply as follows:
Thanks for letting us know - we've now cancelled your visit. If you need any more help, just call...
and a number beginning 0333...
Do I need to call the number?
