Message 1 of 7
M100 slow speed
I'm working from home with remote access. My hub is connected via an ethernet cable. My usual speed and productivity has been stunted by slow broadband speeds over the last two months.
I've just done a speed test and the results are: Ping 37ms, Download 15.06 Mbps, Upload 8.71 Mbps
I'm not a techie but pretty sure this is too slow for a M100 package that I'm paying for?
How can I get the speed up to where it should be please?
Tags (3)
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 7
Re: M100 slow speed
Are you connected to a VPN?
Message 3 of 7
Re: M100 slow speed
Yes, I am
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 7
Re: M100 slow speed
Are you Speedtesting whilst on the VPN?
Message 5 of 7
Re: M100 slow speed
Yes, does that make a difference?
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 7
Re: M100 slow speed
Yes. Because you’re connection is being router out wherever the VPN server is located and is probably bandwidth limited as well.
You need to speedtest wired direct to the hub and not on any VPN
Message 7 of 7
Re: M100 slow speed
I've just run a speed test without the VPN
Ping 11ms Download 111.72 Upload 10.03
You don't need to tell me, the VPN is slowing it down, thanks.
