needmorespeed
Just joined
M100 Fibre Very Slow
Hi. I’ve just signed up for M100 Fibre, and started get 90 Mbps but now I’m only getting under 30 mbps on wifi. Any ideas what I can do?
Eriniusek
Re: M100 Fibre Very Slow
The idea is to break the contract with them. I bought a new 100 mb internet connection and I can't even watch the movie. The only option is to break the contract and take something better. I wrote on the chat and I can not even answer, and I waited all day
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
IP provided Hubs are renowned for their poor Wi-Fi, and at the best of times Wi-Fi is a fickle beast that can be affected by numerous things such as distance from the Hub,  building construction, other electronic devices, neighbouring Wi-Fi, basically all sorts.
VM supply to the Hub, after the Hub it is up to you.
Many on here, myself included advocate the use of a third party Gigabit capable Wi-Fi router or Mesh system.
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
