hruiz
Message 1 of 5
M100 Fibre Broadband at 45Mbps
We have only a couple of weeks contracted with Virgin and at any of the speed test from the initial days until now is providing more than 45 Mbps. As per the contract agreement it should be around 110 - 114 Mbps.
All rebooting process and troubleshooting guides provided by Virgin were completed however, it does not resolve/increase the speed.
The facts:
Two weeks since the service was contracted
All cables and connections are fitted in placed. Virgin socket is new, installed, checked and tested by a Virgin technician before Hub installation/config.
The speed test has been done via wireless on a PC with a Killer Wireless-AC 1435 adapter which data rates up to 867 Mbps.
The results via https://www.speedtest.net/ are: Ping = 15 ms, Download = 45.39 Mbps, Upload = 10.07 Mbps. Tests have been done at 6:40am, 10:00am, 2:00pm, 8:00pm and results are similar (more or less 2 Mbps difference)
14027500001440256 qam30
1Locked40.9187112431
1537000004.2512064 qam8
22/10/2020 19:47:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:20Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:13:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:13:20criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:12:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:12:13Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:12:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:11:40criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:09:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:09:21critical16 consecutive T3 timeouts while trying to range on upstream channel 9;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:09:21criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:01:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:01:7Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:01:7Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:00:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 09:59:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 14:25:17ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: M100 Fibre Broadband at 45Mbps
You only have one Downstream Channel you should have 24 and on that one channel the power level is far too high.
You only have one Upstream Channel and you should have four.
TBH You are very lucky to have a connection.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Hollie_B
  • 932
  • 45
  • 68
Message 3 of 5
Hi there @hruiz
Thanks for your post. Apologies for the delay in response and to hear that you've been having these issues with your broadband.
I will be able to take a look in to this for you, I'll send you a private message now to take a look.
Hollie - Forum Team
jpeg1
  • 4.76K
  • 262
  • 769
Superstar
Message 4 of 5
When the existing problem is fixed, do check your speed with a wired connection to the Hub.
You have done the right thing in getting a better WiFi router, but WiFi speeds are not guaranteed regardless of equipment.
Hollie_B
  • 932
  • 45
  • 68
Message 5 of 5
No worries @hruiz glad that the visit is suitable.
If anything changes please head here to change the visit date and time 🙂
Please pop back if you need anything else,
Hollie - Forum Team
