Artemicion
M100 Consistently Slow Upload Speed
Hi, my M100 connection does a fine job of hitting its promised 100Mbps down, but consistently only gets ~1Mbps up, often slowing to even less than that which makes remote working a real chore. I've noticed that the contractual minimum Virgin pormised is 3Mbps with an advertised speed of 6Mbps, so I'd be able to cancel it given this performance but thought I'd see if anyone has solved this issue before. Issue replicated even by using a LAN cable direct into the router.
Some router status, if this clarifies anything:
402750000
Locked
Ranged Upstream Channel (Hz)
46200180
Locked
Provisioning State
Online
1462001804.45512032 qam1
2258000424.325512032 qam4
3394001664.4512032 qam2
4326000004.375512064 qam3
3ATDMA0000
4ATDMA0000
Appreciate anyone's help, thanks
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Re: M100 Consistently Slow Upload Speed
All 4 upstream should be in 64QAM but only one is.
You'll need an engineer visit.
Artemicion
How disappointing. Is there a way to get one sorted out through the forums? I don't really have 3 hours to sit on the phone to Virgin....
Artemicion
Just ran it again - all four channels actually are 64QAM now:
1462001374.425512064 qam1
2258004544.3512064 qam4
3394001804.4512064 qam2
4326001494.35512064 qam3
3ATDMA0000
4ATDMA0000
Speed test: 0.73Mbps upload speed..... pretty pathetic. Anyone have any other ideas before I'm forced to cancel Virgin or battle for a refund please? Many thanks
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Request an engineer?
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Hi Artemicion,
Thanks for your post.
I'm sorry you're having problems with your upload speed at the moment. I can appreciate you're keen to understand what's going on.
I've had a look at the backend of your services, and I can see that there is currently a congestion issue in your area which you'll be impacted by. The reference number for this is
F008099261 and the current estimated fix time is 22nd July 12:20.
Melissa
