pwhite1989
  • 6
Low speeds
Paying for 200mbps but never actually hitting those speeds. Today for instance I am getting between 10mbps and 50mbps.
Logs:
1427000000-140256 qam37
2267000000-3.738256 qam17
3275000000-3.538256 qam18
4283000000-3.238256 qam19
5291000000-2.938256 qam20
6299000000-2.538256 qam21
7307000000-2.538256 qam22
8315000000-2.438256 qam23
9323000000-1.938256 qam24
10331000000-1.538256 qam25
11339000000-1.438256 qam26
12347000000-138256 qam27
13355000000-138256 qam28
14363000000-138256 qam29
15371000000-1.440256 qam30
16379000000-1.538256 qam31
17387000000-1.438256 qam32
18395000000-1.238256 qam33
19403000000-1.238256 qam34
20411000000-138256 qam35
21419000000-138256 qam36
22435000000-1.540256 qam38
23443000000-1.938256 qam39
24451000000-1.538256 qam40
1Locked40.350
2Locked38.990
3Locked38.950
4Locked38.680
5Locked38.960
6Locked38.650
7Locked38.6140
8Locked38.910
9Locked38.950
10Locked38.660
11Locked38.950
12Locked38.960
13Locked38.650
14Locked38.960
15Locked40.950
16Locked38.660
17Locked38.950
18Locked38.980
19Locked38.950
20Locked38.960
21Locked38.950
22Locked40.300
23Locked38.640
24Locked38.900
15370002950512064 qam2
23940000048512064 qam4
34620000048.5512064 qam3
46030000050512064 qam1
3ATDMA0000
4ATDMA0000
Really upset that there is no phone support - all other companies still have phone support available, why not virgin??
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Low speeds
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Low speeds
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
