P3rcy
Low speeds upstairs
Had virgin hub 5 put in today and next to the hub I get nearly 400mb . In my gaming room upstairs I’m only getting 22mb download speed so games are jumping any ideas how to sort it
  • 20.48K
  • 828
  • 2.2K
Re: Low speeds upstairs
For wifi VM see speed not latency or jitter as 20Mb being fine so if you want a stable connection use a wire
  • 6.81K
  • 592
  • 1.78K
VM only guarantee 20Mb speeds over wifi, so as suggested a cable solution would be best.
You could also look at the Wifi Max solution from VM https://www.virginmedia.com/help/wifi-max
It's free on the top tiers and VOLT, but is £8 pm otherwise.
Carley_S
  • 3.11K
  • 163
  • 263
Hi @P3rcy
Welcome to the community forums
Sorry to hear of your WiFi speed concerns upstairs and with gaming. I can see on the system that you have spoken with the team since posting and have something in place to possible help this for you.
Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
Carley - Forum Team
