Redding43
  • 26
Message 1 of 23
Low speeds on Ultimate Oomph
In the last week or so my speed has dropped from bout 500mb to to best 200mb/80mb
i have tried resetting, rebooting and connecting directly to the Hub3 with a CAT6 cable
On Ethernet I can get sometimes get 200mb and 80mb on WiFi, standing next to the router
Attached are screenshots from the history of my speed tests as well as router status from the hub. Hoping someone can help
Redding43
  • 26
Message 2 of 23
Re: Low speeds on Ultimate Oomph
I have copied the stats in the posts below
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 23
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 23
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 23
Can you please
Redding43
  • 26
Message 6 of 23
402750000
Locked
Ranged Upstream Channel (Hz)
53699974
Locked
Provisioning State
Online
14027500000.440256 qam30
2202750000140256 qam9
3210750000140256 qam10
4218750000140256 qam11
5226750000138256 qam12
6234750000140256 qam13
72427500000.938256 qam14
82507500000.740256 qam15
92587500000.440256 qam16
102667500000.240256 qam17
11274750000040256 qam18
12282750000040256 qam19
13290750000038256 qam20
14298750000038256 qam21
153067500000.240256 qam22
163147500000.440256 qam23
173227500000.540256 qam24
183307500000.540256 qam25
193707500000.540256 qam26
203787500000.538256 qam27
213867500000.538256 qam28
223947500000.440256 qam29
234107500000.238256 qam31
244187500000.238256 qam31
1Locked40.340
2Locked40.360
3Locked40.350
4Locked40.340
5Locked38.950
6Locked40.350
7Locked38.950
8Locked40.340
9Locked40.360
10Locked40.360
11Locked40.360
12Locked40.360
13Locked38.6100
14Locked38.960
15Locked40.350
16Locked40.940
17Locked40.350
18Locked40.340
19Locked40.300
20Locked38.950
21Locked38.960
22Locked40.350
23Locked38.900
24Locked38.900
15369997434512064 qam10
23939997134512064 qam12
34619998334512064 qam11
46029997634512064 qam9
3ATDMA0000
4ATDMA0000
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ldJKDHSUBsgvca69834ncxv987325
SFID19222
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Anonymous
Not applicable
Message 7 of 23
@Redding43 wrote:
Hi Mike, have done that, see the second post
You need to post as text really as some of your images will be rejected for showing things like Public IP, MAC addresses, etc.
When you post as text MAC addresses are automatically starred out.
Redding43
  • 26
Message 8 of 23
SFID19222
Min Traffic Rate0
Primary Upstream Service Flow
SFID19221
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Network LogTime Priority Description
01/01/1970 00:08:9ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:07:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:18ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:56Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 17:38:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 17:34:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 17:34:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 17:29:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 15:04:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 15:04:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 07:10:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 03:04:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 03:04:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 02:09:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 15:04:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 15:04:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2020 09:59:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 17:06:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 17:06:38ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 00:25:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Redding43
  • 26
Message 9 of 23
Thanks all, have copied and pasted in the above
Anonymous
Not applicable
Message 10 of 23
Thanks for sorting it.
The HUB stats don't look to bad to be honest, although the upstream power levels are a little low.
Could you created a BQM and post a live link as Mike suggested?
