joemcd121
  • 37
Message 1 of 36
Low speeds on Gig1
I upgraded to Gig1 two weeks ago, after previously being on M100 package. I wanted to boost the speed significantly since working at home, but the internet speeds I've been getting haven't been up to expectations.
These are the results from a Speed Test over Wi-Fi on Hub 4 (Gig1)
I had read mixed reviews about the Hub 4, so I decided to get Google Nest Wifi to see if that would improve speeds, but that didn't seem to make much difference.
These are results from a Speed Test over Wi-Fi with Google Nest Wifi (Gig1)
Please can someone assist me in helping problem solve? Downstream, upstream & network log to follow.
Thanks, Joe
joemcd121
  • 37
Message 2 of 36
Re: Low speeds on Gig1
Downstream
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
30
402750000
6.4
39
QAM256
30
1
138750000
9.6
38.6
QAM256
1
2
146750000
9.4
38.6
QAM256
2
3
154750000
9.2
38.6
QAM256
3
4
162750000
8.9
38.6
QAM256
4
5
170750000
8.6
38.6
QAM256
5
6
178750000
8.4
38.6
QAM256
6
7
186750000
8.5
38.6
QAM256
7
8
194750000
8.3
38.6
QAM256
8
9
202750000
8.1
39
QAM256
9
10
210750000
7.7
38.6
QAM256
10
11
218750000
7.6
39
QAM256
11
12
226750000
7.4
39
QAM256
12
13
234750000
7.3
38.6
QAM256
13
14
242750000
7.1
39
QAM256
14
15
250750000
7.1
38.6
QAM256
15
16
258750000
7.1
38.6
QAM256
16
17
266750000
7.4
38.6
QAM256
17
18
274750000
7.7
38.6
QAM256
18
19
282750000
7.5
38.6
QAM256
19
20
290750000
7.5
39
QAM256
20
21
298750000
7.3
39
QAM256
21
22
306750000
7.3
38.6
QAM256
22
23
314750000
7.5
39
QAM256
23
24
322750000
7.7
38.6
QAM256
24
25
330750000
7.8
39
QAM256
25
26
370750000
6.6
39
QAM256
26
27
378750000
6.4
39
QAM256
27
28
386750000
6.2
39
QAM256
28
29
394750000
6.2
38.6
QAM256
29
31
410750000
6.5
39
QAM256
31
joemcd121
  • 37
Message 3 of 36
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
30
Locked
38.983261
0
0
1
Locked
38.605377
0
0
2
Locked
38.605377
0
0
3
Locked
38.605377
0
0
4
Locked
38.605377
0
0
5
Locked
38.605377
0
0
6
Locked
38.605377
0
0
7
Locked
38.605377
0
0
8
Locked
38.605377
0
0
9
Locked
38.983261
0
0
10
Locked
38.605377
0
0
11
Locked
38.983261
0
0
12
Locked
38.983261
0
0
13
Locked
38.605377
0
0
14
Locked
38.983261
0
0
15
Locked
38.605377
0
0
16
Locked
38.605377
0
0
17
Locked
38.605377
0
0
18
Locked
38.605377
0
0
19
Locked
38.605377
0
0
20
Locked
38.983261
0
0
21
Locked
38.983261
0
0
22
Locked
38.605377
0
0
23
Locked
38.983261
0
0
24
Locked
38.605377
0
0
25
Locked
38.983261
0
0
26
Locked
38.983261
0
0
27
Locked
38.983261
0
0
28
Locked
38.983261
0
0
29
Locked
38.605377
0
0
31
Locked
38.983261
0
0
joemcd121
  • 37
Message 4 of 36
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
86
4K
1680
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
33
Locked
41
6.6
256136
0
joemcd121
  • 37
Message 5 of 36
Upstream
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
38.8
5120 KSym/sec
16QAM
5
2
46200000
38.3
5120 KSym/sec
64QAM
3
3
39400000
38.5
5120 KSym/sec
64QAM
4
4
25800000
38.8
5120 KSym/sec
32QAM
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
joemcd121
  • 37
Message 6 of 36
Time
Priority
Description
Thu 01/01/1970 00:01:24
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 02/01/2021 23:44:55
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 03/01/2021 00:44:34
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 03/01/2021 16:40:25
3
Wed 06/01/2021 12:44:35
4
Wed 06/01/2021 14:27:41
3
Sun 10/01/2021 00:44:35
4
Sun 10/01/2021 12:51:26
3
Mon 11/01/2021 00:07:41
6
SW Download INIT - Via NMS
Mon 11/01/2021 00:13:56
6
SW download Successful - Via NMS
Mon 11/01/2021 00:16:32
5
Mon 11/01/2021 18:40:00
3
Mon 11/01/2021 20:51:03
5
Anonymous
Not applicable
Message 7 of 36
@joemcd121 wrote:
Upstream
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
38.8
5120 KSym/sec
16QAM
5
2
46200000
38.3
5120 KSym/sec
64QAM
3
3
39400000
38.5
5120 KSym/sec
64QAM
4
4
25800000
38.8
5120 KSym/sec
32QAM
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
Two of your upstream channels are out of spec (highlighted) which could be noise on the line.
Setup a BQM and post a live link.
You may also want to run a wired speed test to satisfy that WiFi isn't the limitation.
Don't expect WiFi to run at 1Gbps!
joemcd121
  • 37
Message 8 of 36
BQM link:
https://www.thinkbroadband.com/broadband/monitoring/quality/view/b7620eb76308854bd05008bb4e047655c35...
I meant to say in my original post sorry, that speeds via Ethernet were also around 400mbps down, 50 up.
Thanks, Joe
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 36
Your BQM Link gives a '404 - Page Not Found' error.
joemcd121
  • 37
Message 10 of 36
Apologies. Try this instead:
BQM LINK
