on 08-01-2022 12:37
My broadband 200 has been running at between 90-130 for a few weeks, it's the same if my devices are wired or on wifi
on 08-01-2022 12:43
Usual request, post your power levels, Pre and PostRS errors and Network log. Also setup a BQM here www.thinkbroadband.com/ping
Once done we can comment on your stats.
on 08-01-2022 12:47
1 267000000 4.5 35 256 qam 17
2 139000000 2.4 35 256 qam 1
3 147000000 2.5 35 256 qam 2
4 155000000 2.5 35 256 qam 3
5 163000000 2.5 35 256 qam 4
6 171000000 2.9 35 256 qam 5
7 179000000 3 35 256 qam 6
8 187000000 3 35 256 qam 7
9 195000000 2.7 35 256 qam 8
10 203000000 2.7 35 256 qam 9
11 211000000 3 35 256 qam 10
12 219000000 3.2 35 256 qam 11
13 227000000 3.2 35 256 qam 12
14 235000000 3.4 35 256 qam 13
15 243000000 3.9 35 256 qam 14
16 251000000 4 35 256 qam 15
17 259000000 4.4 35 256 qam 16
18 275000000 4.5 36 256 qam 18
19 283000000 4.8 36 256 qam 19
20 291000000 4.5 35 256 qam 20
21 299000000 4.6 35 256 qam 21
22 307000000 4.5 35 256 qam 22
23 315000000 4.5 35 256 qam 23
24 323000000 4.3 35 256 qam 24
on 08-01-2022 12:47
1 Locked 35.7 16497 0
2 Locked 35 42681536 3332038
3 Locked 35 7815883 4476476
4 Locked 35.5 9098189 1780018
5 Locked 35.5 7495480 586400
6 Locked 35.5 3702840 21323
7 Locked 35.7 429255 0
8 Locked 35.5 77223 0
9 Locked 35.5 80916 0
10 Locked 35.5 88776 0
11 Locked 35.5 114507 0
12 Locked 35.5 122401 0
13 Locked 35 155325 0
14 Locked 35 274394 0
15 Locked 35.7 63148 0
16 Locked 35.5 39165 0
17 Locked 35.7 24939 0
18 Locked 36.3 9316 0
19 Locked 36.6 8818 0
20 Locked 35.7 19086 0
21 Locked 35.7 21020 0
22 Locked 35.7 23972 0
23 Locked 35.7 28398 0
24 Locked 35.7 30965 0
on 08-01-2022 12:48
1 60300000 45.5 5120 64 qam 1
2 46200000 46.5 5120 64 qam 3
3 53699955 46 5120 64 qam 2
4 39400000 46.8 5120 64 qam 4
1 ATDMA 0 0 10 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 1 0
08-01-2022 12:49 - edited 08-01-2022 12:49
Looking at the number of errors on your downstream channels, depending on how long the HUB has been powered on since the last reboot, there may be a local outage.
on 10-01-2022 13:33
Hi @Stevefrog1981, thanks for your post and I'm sorry to hear your speeds are lower than expected.
I've had a look at your account and at this moment (I appreciate this may change), there aren't any devices connected via ethernet but there are also no local area outages either.
Are you able to kindly post a screenshot of a speed test that you conduct via ethernet connection please through this link?
