GitSmackt
  • 12
Message 1 of 13
Low gig 1 speeds
Ordered the new gig 1 package and got it yesterday, but ever since I've had it I've had nothing but issues with my speed.
I'm not even reaching anywhere near 1 Gbps speeds. I get around 300-400 at most.
I am also connected to the hub via an ethernet cable.
Bit annoyed tbh, because I didn't upgrade just to get near enough the same speeds as my last package (M350)
GitSmackt
  • 12
Message 2 of 13
Re: Low gig 1 speeds
3.0 Downstream channels
1 139000000 9.900002 38.983261 QAM256 1
2 147000000 9.900002 38.983261 QAM256 2
3 155000000 9.900002 40.366287 QAM256 3
4 163000000 9.699997 38.983261 QAM256 4
5 171000000 9.500000 38.983261 QAM256 5
6 179000000 9.500000 38.983261 QAM256 6
7 187000000 9.400002 40.366287 QAM256 7
8 195000000 9.199997 40.366287 QAM256 8
9 203000000 9.199997 38.983261 QAM256 9
10 211000000 9.000000 38.983261 QAM256 10
11 219000000 8.900002 38.983261 QAM256 11
12 227000000 8.800003 38.983261 QAM256 12
13 235000000 8.400002 38.983261 QAM256 13
14 243000000 8.199997 38.983261 QAM256 14
15 251000000 8.199997 38.983261 QAM256 15
16 259000000 8.000000 38.605377 QAM256 16
17 267000000 8.099998 38.983261 QAM256 17
18 275000000 8.199997 38.983261 QAM256 18
19 283000000 8.300003 38.983261 QAM256 19
20 291000000 8.199997 38.983261 QAM256 20
21 299000000 8.000000 40.366287 QAM256 21
22 307000000 7.599998 38.983261 QAM256 22
23 315000000 7.099998 38.983261 QAM256 23
24 323000000 7.300003 38.605377 QAM256 24
25 363000000 8.000000 38.605377 QAM256 25
26 371000000 7.900002 38.983261 QAM256 26
27 379000000 8.199997 38.983261 QAM256 27
28 387000000 8.000000 38.605377 QAM256 28
29 395000000 8.099998 38.983261 QAM256 29
30 403000000 8.000000 38.983261 QAM256 30
31 411000000 7.699997 38.983261 QAM256 31
1 Locked 0 1 0
2 Locked 110713489 0 0
3 Locked 110744248 0 0
4 Locked 110438040 0 0
5 Locked 110465491 0 0
6 Locked 110382822 0 0
7 Locked 110639928 0 0
8 Locked 24283481 0 0
9 Locked 34793506 0 0
10 Locked 34638420 0 0
11 Locked 14265748 0 0
12 Locked 34064245 0 0
13 Locked 33921947 1 0
14 Locked 33705005 8 0
15 Locked 33390694 1 0
16 Locked 36829124 1 0
17 Locked 36669128 0 0
18 Locked 36720747 1 0
19 Locked 36997577 2 0
20 Locked 36887138 2 0
21 Locked 37130442 1 0
22 Locked 36853945 3 0
23 Locked 36552807 1 0
24 Locked 52006274 2 0
25 Locked 51913386 3 0
26 Locked 51974784 0 0
27 Locked 51650827 1 0
28 Locked 51907411 1 0
29 Locked 51641498 2 0
30 Locked 51884032 0 0
31 Locked 318984402 2 0
3.1 Downstream channels
159 96 4K 1880 QAM4096 759
159 Locked 2.2 7826908 0
GitSmackt
  • 12
Message 3 of 13
Cable Modem Status
Item Status Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
GitSmackt
  • 12
Message 4 of 13
3.0 Upstream channels
1 46200000 39.020599 5120 KSym/sec 64QAM 3
2 39400000 38.270599 5120 KSym/sec 64QAM 4
3 53700000 39.770599 5120 KSym/sec 64QAM 2
4 60300000 40.770599 5120 KSym/sec 64QAM 1
1 US_TYPE_STDMA 0 0 0 4
2 US_TYPE_STDMA 0 0 0 4
3 US_TYPE_STDMA 0 0 0 4
4 US_TYPE_STDMA 0 0 0 4
GitSmackt
  • 12
Message 5 of 13
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
g87dsfd;kfoA,.iyewrkldJKD
SFID
14212
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
14211
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 13
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
GitSmackt
  • 12
Message 7 of 13
on SamKnows I get full speeds to the hub. Yet when I use any other speedtest website (Fast.com, speedtest.net) etc..I get around 300-400. Then it'll skyrocket to about 800 and vice versa.
When I download games I only average about 30-40 Mb/s when I should be reaching 100+ Mb/s
My connection is very unstable atm and idk why.
So although it shows I have 1000 Mbps on SamKnows, I don't actually get them speeds when downloading games which should be around (117.5 Mb/s)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 13
Are you using Wi-Fi or ethernet cable connection while doing the downloads that you mentioned ?
GitSmackt
  • 12
Message 9 of 13
I am connected via Cat 6 Ethernet Cable directly into the Hub 4.
This is My BQM
GitSmackt
  • 12
Message 10 of 13
Bump
