discogp
Message 1 of 9
Low download speed on Gig1
Hello,
I have upgraded my Virgin connection to the Gig1 about a month ago.  I have never really been able to experience speeds close to 1Gbps and speeds are only averaging around 400Mbps via direct CAT6 cable connection.  The most I have been able to get was around 816Mbps, but only briefly.
It looks like i have 1 DOCSIS3.1 channel active on my Hub4, but looks like there are some errors:
I was wondering if someone can advise why I may be experiencing this issue and what my options are.  I have phoned the Virgin Support guys a number of times, only to be told to reset or reboot the router with no real solution to the issue.  Any help would be appreciated.
Thanks.
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 2 of 9
Re: Low download speed on Gig1
@discogp wrote:
Hello,
Thanks.
What does this site show:
https://samknows.com/realspeed/
discogp
Message 3 of 9
At the moment when I use https://samknows.com/realspeed/ it shows 1144 but other times it can be 890.  It does seem to be very intermittent.
3.1 Downstream channels
159964K1880QAM4096392
159Locked388.783800612635184
Does the value under the Uncorrectables (Active Profile) raise any cause for concerns?
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 4 of 9
You shouldn't have any uncorrected errors on any of the channels (Corrected are ok) so yes, it is a cause for concern.
Could you post the upstream tab data please?
gitty
  • 190
  • 47
Superfast
Message 5 of 9
How does the modem log looks like?
Paulina_Z
  • 4.31K
  • 159
  • 327
Message 6 of 9
Hi @discogp,
Welcome to our Community Forums! Thank you for your first post, and I'm sorry to hear that you're experiencing some ongoing issues with your broadband speeds! I understand how frustrating this can be.
I was able to locate your account, however, your Hub is showing as not connected to our network.
Please reboot your Hub and once this is done, please come back to us and we'll run some further checks on your account and see how we can help with this.
Thank you.
Paulina_Z
discogp
Message 7 of 9
  • 3.0 Upstream channels
139400000455120 KSym/sec64QAM2
22580000044.35120 KSym/sec64QAM4
332600000455120 KSym/sec64QAM3
446200000455120 KSym/sec64QAM1
Here are the upstream logs:
1US_TYPE_STDMA0020
2US_TYPE_STDMA0010
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
discogp
Message 8 of 9
I have rebooted the hub as requested.
Thanks.
Gareth_L
  • 10.77K
  • 600
  • 1.19K
Message 9 of 9
Hello discogp
Thanks for that
We have checked again and the Downstream levels are a bit out
Which would need to be fixed by a Service Technician
So I can book this out
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
