DaveT52
Low broadband speed?
I have the M100 package (advertised download speeds of 108Mbps) but every test I run shows a download speed of between 1.7 Mbps and 2.9 Mbps. Upload speed is steady at 10 Mbps. Surely this is slow?! Any help appreciated.
First TimeLast TimePriorityError NumberDescription
22/09/2020 23:25:27 GMT22/09/2020 23:25:27 GMTWarning (5)66050310Auth Success - Web login successful.
22/09/2020 23:25:01 GMT22/09/2020 23:25:01 GMTWarning (5)66050310Auth Success - Web login successful.
22/09/2020 23:24:16 GMT22/09/2020 23:24:16 GMTWarning (5)66050310Auth Success - Web login successful.
22/09/2020 23:18:51 GMT22/09/2020 23:18:51 GMTWarning (5)66050310Auth Success - Web login successful.
22/09/2020 11:16:48 GMT22/09/2020 11:16:48 GMTWarning (5)84020200Lost MDD Timeout
22/09/2020 11:16:47 GMT22/09/2020 11:16:47 GMTWarning (5)84020200Lost MDD Timeout
22/09/2020 11:16:46 GMT22/09/2020 11:16:46 GMTWarning (5)84020200Lost MDD Timeout
22/09/2020 11:16:42 GMT22/09/2020 11:16:42 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
22/09/2020 11:16:41 GMT22/09/2020 11:16:41 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
22/09/2020 11:15:55 GMT22/09/2020 11:15:55 GMTWarning (5)84020200Lost MDD Timeout
22/09/2020 11:15:54 GMT22/09/2020 11:15:54 GMTWarning (5)84020200Lost MDD Timeout
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000155000000163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)3.373.313.143.153.313.473.483.42
RxMER (dB)36.1736.6136.3936.1737.0949.4037.0937.09
Pre RS Errors6968707168855729954729571767336
Post RS Errors5411534452003950684829146735678
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID5234
Frequency (Hz)32600000537000004620000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)43.2545.5044.2543.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts11100
T4 Timeouts0000
Tags (1)
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Re: Low broadband speed?
Hiya,
I have taken a look at your post and i can't actually really see anything wrong apart from Number 6 downstream being a little high.
Are you connected via wireless or wired when you are doing tests?
Have you tried to hold the reset button in for 30 seconds on the back of the Hub and then released and see if going back to defaults is any different?
Hit me back and i'm sure someone will take a closer look into this for you.
Anonymous
Not applicable
DS-6 looks fine.
Nothing wrong with them stats
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Hello
Looks like a noise issue as some T3 / T4 errors as well as the high number of post RS errors, one thing I would do would be to go around and make sure that all coaxial connections to all VM equipment are finger tight best way to do this is too loosen the connector and then re tighten, once that has been done power off hub for 30 secs and then back on.
If the Post RS errors are rising at a large rate then an engineer will be needed to resolve the problem.
Regards Mike
