clebenstein
  • 12
Message 1 of 20
Low Wifi Speeds after Powercut
Hello, we've recently had a power cut and wifi download speeds and ping have been fluctuating. I am on a 350mbps connection with a Hub 3.0, but speeds have dropped down to 100, then 60 and then eventually less than 10mbps as the day progresses.
I haven't had much luck getting through on the phone to support so I am posting my problem here. I've tried repositioning my wireless devices (still poor download speeds right next to the router), I have rebooted and one a factory reset on the router which also didn't work. I have also tried using a third party tp-link router and put the hub in modem mode to see if that resolved the issue, which it unfortunately did not. I am currently a student studying from home and I depend on a steady internet to successfully attend online lecture, which has become problematic since the issue arose. I would greatly appreciate any advice or help anyone could lend.
Thankyou in advance!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 20
Re: Low Wifi Speeds after Powercut
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
clebenstein
  • 12
Message 3 of 20
Thankyou for the response, ive just tried it with a wired connection and I'm still only getting download speeds of 20mbps and 14ping. Curiously my upload speeds are still 38mbps as they normally are
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 20
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 20
Can you please
clebenstein
  • 12
Message 6 of 20
My BQM
Thankyou for taking the time to help me, it's very much appreciate. I will post the network log now if it lets me
clebenstein
  • 12
Message 7 of 20
14190000005.140256 qam32
22030000005.440256 qam9
32110000005.640256 qam10
42190000005.340256 qam11
52270000005.140256 qam12
62350000005.340256 qam13
72430000005.440256 qam14
8251000000540256 qam15
9259000000540256 qam16
10267000000540256 qam17
112750000005.540256 qam18
122830000005.440256 qam19
13291000000540256 qam20
14299000000540256 qam21
153070000005.540256 qam22
163150000005.540256 qam23
17323000000540256 qam24
183630000005.340256 qam25
193710000004.840256 qam26
203790000005.340256 qam27
21387000000540256 qam28
223950000005.440256 qam29
234030000005.440256 qam30
244110000005.140256 qam31
1Locked40.3120
2Locked40.311194
3Locked40.340
4Locked40.350
5Locked40.950
6Locked40.360
7Locked40.360
8Locked40.300
9Locked40.950
10Locked40.960
11Locked40.960
12Locked40.360
13Locked40.940
14Locked40.300
15Locked40.300
16Locked40.350
17Locked40.350
18Locked40.900
19Locked40.300
20Locked40.950
21Locked40.950
22Locked40.980
23Locked40.9130
24Locked40.360
clebenstein
  • 12
Message 8 of 20
1536999664.275512064 qam2
2393999884.275512064 qam4
3461999984.275512064 qam3
4603000004.275512064 qam1
3ATDMA0000
4ATDMA0000
clebenstein
  • 12
Message 9 of 20
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9834ncxv9873254k;fg87dsfd
SFID25585
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID25584
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
clebenstein
  • 12
Message 10 of 20
10/11/2020 18:23:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:14:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:11:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 18:11:10Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 17:25:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 19:43:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 19:43:3Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 17:14:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 17:13:52Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 17:13:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 13:51:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:01:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 19:57:17noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:49:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:40:50noticeSW download Successful - Via Config file
08/11/2020 13:38:56noticeSW Download INIT - Via Config file
01/01/1970 00:02:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:34:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 09:25:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 16:40:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
