Low Broadband Speed
I was upgraded to M100 from M50 a while ago. The speed check was at 100 download and upload speed was good.
Over the past 2 days, download speed is around 40. Upload speed seems ok.
I have check connections and reset the hub numerous times.
Service check and speed test (VIRGIN MEDIA)  state no problem. Independent tests all say its very slow.
Help needed please?
  • 15.68K
  • 1.64K
  • 2.67K
Re: Low Broadband Speed
Firstly - what Hub model do you have ?
Are you testing over wifi or via ethernet cable.
If wifi - try again on a computer/laptop wired directly to the Hub with Cat5e/6 ethernet cable with the Hub switched into modem mode. Report back what that gets.
I have the superhub and have ordered the new one. I have just retested on hard wire and it is now back up to speed. 104 mMbps. It was half that over last 2 days also on hardwire.
We'll see how it goes.
Many thanks for you reply.
