MJF27
Los of speed following locality upgrade
2 days ago my street was upgraded. My speed has reduced from 200Mbps to under 50, sometimes as low as 10
Help please
  • 32K
  • 3.14K
  • 6.07K
Re: Los of speed following locality upgrade
Try a pinhole reset of the Hub first.
_____________________________
Make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
SSID's and passwords will revert to those printed on the sticket - so you may to change them to what you had.
See if that sorts it first.
Serena_C
  • 2.19K
  • 91
  • 214
Hi @MJF27
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the slow speeds you have been experiencing since your street was upgraded.
Did you try a pinhole reset on your Hub as @jbrennand advised? Has this improved your speeds?
Please also take a look at https://virg.in/SpeedUp for more information on improving your speeds 🙂
Kind regards,
Serena
