RupertL
London SW19 V Slow sub 5mbps in day - pls help
Downstream, Upstream and Log from Hub 3.0 :
DateDown HTTPx6Down HTTPx1Upstream
Wed 03/06/2020 11:153.57 Mbps2.38 Mbps1.41 Mbps
Wed 03/06/2020 10:023.44 Mbps3.43 Mbps1.38 Mbps
Wed 03/06/2020 07:4011.21 Mbps7.07 Mbps4.50 Mbps
Wed 03/06/2020 07:2315.53 Mbps18.14 Mbps4.98 Mbps
Wed 03/06/2020 07:114.00 Mbps5.92 Mbps0.81 Mbps
Tue 02/06/2020 22:386.21 Mbps7.64 Mbps1.01 Mbps
129900000019.436256 qam21
213900000017.536256 qam1
314700000017.536256 qam2
415500000017.536256 qam3
516300000017.536256 qam4
617100000017.536256 qam5
717900000017.536256 qam6
818700000017.836256 qam7
919500000017.637256 qam8
1020300000017.537256 qam9
1121100000017.436256 qam10
122190000001736256 qam11
1322700000016.936256 qam12
1423500000016.936256 qam13
152430000001736256 qam14
1625100000017.436256 qam15
172590000001836256 qam16
1826700000018.536256 qam17
1927500000018.937256 qam18
2028300000018.937256 qam19
2129100000018.937256 qam20
2230700000019.437256 qam22
2331500000019.637256 qam23
243230000002037256 qam24
1Locked36.6170
2Locked36.670
3Locked36.660
4Locked36.660
5Locked36.660
6Locked36.660
7Locked36.6240
8Locked36.3180
9Locked37.350
10Locked37.380
11Locked36.6140
12Locked36.678040
13Locked36.3170
14Locked36.6100
15Locked36.670
16Locked36.660
17Locked36.660
18Locked36.650
19Locked37.330
20Locked37.380
21Locked37.360
22Locked37.360
23Locked37.3180
24Locked37.300
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1603000143.125512064 qam1
2394000073.125512064 qam4
3462000093.125512064 qam3
4537000043.125512064 qam2
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
RupertL
Re: London SW19 V Slow sub 5mbps in day - pls help
TimePriorityDescription
03/06/2020 10:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 10:32Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 19:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 12:32noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 12:32ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 12:13ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 12:02criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 16:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 20:03criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 16:39noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 16:39ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 14:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 14:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 09:09ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 04:09criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 02:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 02:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 06:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2020 12:09criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 12:45noticeDHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
RupertL
having just switched to my 5ghz signal (slightly weaker) and not 2.4ghz it has for the moment just significantly improved the situation, so actually for the moment I'm ok (although that hasn't worked in the past!)
