audetto74
  • 143
  • 17
Dialled in
Message 1 of 10
Lockdown N.3 => Upload Speed < 1MB
In AL5,
lockdown N3 just started, kids at home, my upload speed goes down to < 1MB, remote working experience really poor.
It should be 10MB, but it is back at the levels of Spring 2020.
Ethernet, directly connected to the router, download always good at 105MB.
What can be done to bring it to a decent level? Something between 5 and 10?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Lockdown N.3 => Upload Speed < 1MB
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
audetto74
  • 143
  • 17
Dialled in
Message 5 of 10
Speed: 113 Download, 2.52 Upload (and this is at 7PM, off peak, during the day it is a lot less).
https://www.thinkbroadband.com/broadband/monitoring/quality/share/497b16064ae3540636e6069fcbf3fda225571959
audetto74
  • 143
  • 17
Dialled in
Message 6 of 10
14990000007.540256 qam12
24910000007.540256 qam11
35070000007.540256 qam13
45150000007.940256 qam14
55230000007.540256 qam15
65310000007.340256 qam16
75390000007.440256 qam17
8547000000740256 qam18
9555000000740256 qam19
105630000006.840256 qam20
115710000006.840256 qam21
125790000006.640256 qam22
135870000006.340256 qam23
145950000006.640256 qam24
156350000006.540256 qam25
166430000006.440256 qam26
17651000000640256 qam27
186590000006.440256 qam28
196670000006.440256 qam29
206750000006.840256 qam30
21683000000740256 qam31
226910000006.840256 qam32
236990000006.840256 qam33
247070000006.840256 qam34
1Locked40.35920
2Locked40.312680
3Locked40.93480
4Locked40.95770
5Locked40.37990
6Locked40.312370
7Locked40.93850
8Locked40.95030
9Locked40.94690
10Locked40.313540
11Locked40.39660
12Locked40.34300
13Locked40.99780
14Locked40.94400
15Locked40.38680
16Locked40.36710
17Locked40.37560
18Locked40.33190
19Locked40.35330
20Locked40.35640
21Locked40.37170
22Locked40.94830
23Locked40.92670
24Locked40.95980
audetto74
  • 143
  • 17
Dialled in
Message 7 of 10
Upstream
13940003541512064 qam2
24620016441.3512064 qam1
32579994641512016 qam4
43260026341512064 qam3
1ATDMA00180
2ATDMA00190
3ATDMA00190
4ATDMA00100
audetto74
  • 143
  • 17
Dialled in
Message 8 of 10
Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID9366
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID9365
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
audetto74
  • 143
  • 17
Dialled in
Message 9 of 10
05/01/2021 14:30:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 11:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2021 18:46:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 12:39:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 21:36:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 20:56:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 11:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 20:18:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 20:19:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 11:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 22:27:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 12:21:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 11:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2020 15:59:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 23:58:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
audetto74
  • 143
  • 17
Dialled in
Message 10 of 10
SamKnows
  • 8:00 AM Upload speed 10MB
  • 10:30 AM: Upload speed 650KB
I get about 1/15 of what I pay for.
