dwu
  • 27
  • 5
Message 1 of 7
Less than 1Mbps on a 200Mbps line
My internet speed has been abysmal for the past 2-3 weeks. Seeming to get progressively slower each day - dropping to 15 to 8 to 5 to 2.5 and now to under 1Mbps. Just done a speed test and got 0.93Mbps. When you're working from home, trying to use remote desktop software, it's causing all kinds of headaches.
I've done all the usual troubleshooting steps (rebooting, wired connection, etc.) and nothing improves.
My downstream data from my modem:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1203000000438256 qam9
2211000000438256 qam10
32190000003.536256 qam11
42270000003.537256 qam12
52350000003.240256 qam13
6243000000340256 qam14
72510000002.740256 qam15
8259000000340256 qam16
92670000003.740256 qam17
102750000003.540256 qam18
112830000003.740256 qam19
122910000003.240256 qam20
132990000003.940256 qam21
143070000003.940256 qam22
153150000003.540256 qam23
16323000000340256 qam24
173630000002.240256 qam25
183710000002.440256 qam26
193790000001.940256 qam27
203870000001.940256 qam28
213950000000.738256 qam29
224030000001.240256 qam30
234110000000.740256 qam31
244190000000.438256 qam32
1Locked38.91218112373
2Locked38.91195313955
3Locked36.31613117837
4Locked37.61254317626
5Locked40.3936513208
6Locked40.9930010438
7Locked40.389068017
8Locked40.377667048
9Locked40.374069349
10Locked40.3715913313
11Locked40.9732416113
12Locked40.3681415836
13Locked40.9648014117
14Locked40.356719251
15Locked40.356617072
16Locked40.957055244
17Locked40.3557111094
18Locked40.3567512677
19Locked40.3629210754
20Locked40.351767132
21Locked38.977736943
22Locked40.348543726
23Locked40.348794654
24Locked40.357655535
Hopefully someone can help because this is driving me nuts and it's next to impossible to speak to anyone via phone at the moment.
Roger_Gooner
  • 6.53K
  • 472
  • 1.14K
Legend
Message 2 of 7
Re: Less than 1Mbps on a 200Mbps line
I don't like the look of the Post RS Errors. Can you power off your hub, check that all cable connections from hub to wall socket are tight and reboot the hub. Post your downstream, upstream and logs making sure to mask any WAN IP address. Also check your speeds with a wired connection using speedtest.net.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
dwu
  • 27
  • 5
Message 3 of 7
Already done all of the above re: checking cables, reboots, etc. numerous times. Doesn't help. This PC is always connected via wired connection, so that's not an issue.
Other requested info to follow.
dwu
  • 27
  • 5
Message 4 of 7
12030000003.738256 qam9
22110000003.738256 qam10
32190000003.235256 qam11
42270000003.238256 qam12
5235000000340256 qam13
62430000002.740256 qam14
72510000002.440256 qam15
82590000002.740256 qam16
92670000003.240256 qam17
10275000000340256 qam18
112830000003.540256 qam19
12291000000340256 qam20
132990000003.540256 qam21
143070000003.540256 qam22
153150000003.240256 qam23
163230000002.740256 qam24
17363000000240256 qam25
18371000000240256 qam26
193790000001.540256 qam27
203870000001.540256 qam28
213950000000.438256 qam29
22403000000140256 qam30
234110000000.540256 qam31
244190000000.238256 qam32
1Locked38.91451613915
2Locked38.91414815547
3Locked35.71847419633
4Locked38.91472519912
5Locked40.91123014704
6Locked40.31107811815
7Locked40.3105779152
8Locked40.992418146
9Locked40.3883210795
10Locked40.3853414682
11Locked40.9858017914
12Locked40.9803217338
13Locked40.9765215752
14Locked40.3678310577
15Locked40.367038090
16Locked40.966976091
17Locked40.9652112721
18Locked40.3660114344
19Locked40.3720912510
20Locked40.960648080
21Locked38.987187890
22Locked40.356524684
23Locked40.356245650
24Locked38.965366777
dwu
  • 27
  • 5
Message 5 of 7
1603000004.975512064 qam1
2462000004.8512064 qam3
3394000004.725512064 qam4
4537000004.875512064 qam2
3ATDMA0000
4ATDMA0000
dwu
  • 27
  • 5
Message 6 of 7
Network LogTime Priority Description
04/05/2020 14:37:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 14:37:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 10:19:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 01:51:49ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 16:12:38ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 11:20:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 06:33:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 23:56:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 23:56:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 23:56:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 23:56:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2020 14:07:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2020 06:58:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 14:22:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 07:45:39criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 07:42:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 07:39:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 07:39:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 07:39:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Roger_Gooner
  • 6.53K
  • 472
  • 1.14K
Legend
Message 7 of 7
Although your power levels are within spec there is a problem because the Post RS Errors keep rising. a VM tech needs to be sent round to investigate.
