PdAUK
  • 20
  • 5
Message 1 of 42
Latency spikes - low quality MS teams calls
I'm working from home and getting fed up with the latency when doing MS teams calls for work. I'm using a high spec laptop connected via ethernet to the network and I can't get thru calls without audio and video loss happening every 10 or so minutes. Sometimes it's fine but other times it gets tough to understand people and asking people to constantly repeat themselves. Very annoying.
I managed to capture an example using azure latency check and you can see latency is usually 40ms or so but then spikes to 600ms for 5sec or more....
IMG-20201102-WA0002.jpgdecided to run simultaneous ping to four points (from left to right): my gateway , the first VM network IP I found doing a tracert, an intermediate VM network point, lastly a server I use for work.
Usual story that packets to my router is working fast, but the ping spikes on the VM network. One example here below:
In other examples the first VM point (2nd screen from left) can also spike. Never my internal network.
I've restarted the router, checked the coax is securely connected and nothing has changed recently with my setup.
Using M200 service.
Is this normal and expected for consumer grade internet services? Is anyone else having these issues?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 42
Re: Latency spikes - low quality MS teams calls
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 42
Can you please
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 42
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
PdAUK
  • 20
  • 5
Message 5 of 42
Downstream
1402750000540256 qam25
21867500005.540256 qam7
31947500005.540256 qam8
42027500005.940256 qam9
52107500006.140256 qam10
62187500006.340256 qam11
7226750000640256 qam12
82347500005.840256 qam13
92427500005.840256 qam14
102507500006.140256 qam15
11258750000640256 qam16
12266750000640256 qam17
132747500005.940256 qam18
142827500006.340256 qam19
152907500006.540256 qam20
162987500006.440256 qam21
173067500006.140256 qam22
183147500006.140256 qam23
193227500006.340256 qam24
204107500005.140256 qam26
214187500005.540256 qam27
224267500005.640256 qam28
23434750000540256 qam29
24442750000540256 qam30
1Locked40.3360
2Locked40.31090
3Locked40.9450
4Locked40.9340
5Locked40.3200
6Locked40.9260
7Locked40.9240
8Locked40.3930
9Locked40.9350
10Locked40.9470
11Locked40.9230
12Locked40.3300
13Locked40.3400
14Locked40.3260
15Locked40.3300
16Locked40.3350
17Locked40.3550
18Locked40.9280
19Locked40.9320
20Locked40.3190
21Locked40.3320
22Locked40.9450
23Locked40.3870
24Locked40.3900
13940026842.3512064 qam2
24620027842.3512064 qam1
32580001540.8512064 qam4
43260000041.5512064 qam3
2ATDMA0010
3ATDMA0000
4ATDMA0000
PdAUK
  • 20
  • 5
Message 6 of 42
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID186182
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID186181
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
PdAUK
  • 20
  • 5
Message 7 of 42
09/11/2020 02:24:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 12:53:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 18:48:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 00:53:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 19:07:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 12:53:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 17:48:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 12:53:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 20:15:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 12:20:54ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 00:12:40noticeSW download Successful - Via NMS
14/10/2020 00:09:22noticeSW Download INIT - Via NMS
12/10/2020 00:25:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 11:31:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 12:25:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2020 09:29:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2020 00:25:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 17:25:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 00:25:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
PdAUK
  • 20
  • 5
Message 8 of 42
Speedtest.com
Ping 12ms
Down 206.22 Mbps
Up 21.04 Mbps
Although these speedtest results are generally ok when I have attempted these before.
PdAUK
  • 20
  • 5
Message 9 of 42
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b99c398512649ed92685b359b63627ebbfa22d3a
Pls ignore initial packet loss.
MrHalfAsleep
  • 2.5K
  • 71
  • 978
Problem sorter
Message 10 of 42
MS Teams doesn't get a good write up here: https://downdetector.co.uk/status/teams/map/
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
Some video posts may contain swearing/inappropriate content for young children
π
