Jakemarques7
  • 8
Message 1 of 15
Latency issue
Hi all,
look at this rubbish, latency drops out even though I am wired to my router via Ethernet on my pc & PS5 and still have this to deal with.
getting fed up with this. Any help would be appreciated
Tags (3)
  • 20.42K
  • 827
  • 2.2K
Message 2 of 15
Re: Latency issue
Any better in modem mode?
Jakemarques7
  • 8
Message 3 of 15
Re: Latency issue
Nope, still same issues
Paul_DN
  • 10.66K
  • 545
  • 1.09K
Message 4 of 15
Re: Latency issue
Hi Jakemarques7,
Thank you for reaching out to us in our community and welcome, sorry to see you are facing latency issues, I was unable to locate you on our system with the details we have for you, so I can try to help and have a closer look at things, I will send you an invite into a private chat, once received plaease click on the purple envelope to accept.
Paul.
Jakemarques7
  • 8
Message 5 of 15
Re: Latency issue
Hi, since this ive had 4 Engineers out and still have the same issues
Thinkbroadband QM
Really Really fed up now
jpeg1
  • 7.5K
  • 389
  • 1.46K
Legend
Message 6 of 15
Re: Latency issue
Looks like you have too many neighbours WFH and the local network is struggling to cope.
Unless you can persuade VM to do some upgrading you will just have to put up with it or go elsewhere.
Jakemarques7
  • 8
Message 7 of 15
Re: Latency issue
What do you advise?
BT is attatched below but drastically slower speeds. would they be better for latency in my case?
jpeg1
  • 7.5K
  • 389
  • 1.46K
Legend
Message 8 of 15
Re: Latency issue
Your image is waiting to pass moderation. I'll check back later.
Jakemarques7
  • 8
Message 9 of 15
Re: Latency issue
speeds between 25-40 'Fibre 1' its called
jpeg1
  • 7.5K
  • 389
  • 1.46K
Legend
Message 10 of 15
Re: Latency issue
If latency is that important to you, VDSL may well be better. You could try it out and if it doesn't do what you want you can cancel within 14 days without charge.
Or you could wait until Openreach brings FTTP to your area. It would definitely be better:
https://www.openreach.com/fibre-broadband/where-when-building-ultrafast-full-fibre-broadband
Check whether Community Fibre or Hyperoptic or one of the other altnets is available to you.
