ince1
  • 10
Latency and packet loss causing issues
It’s another thread about latency and packet loss causing issues with VoIP and games.
I’m finding ping hitting 1000ms+ during the day which just isn’t acceptable, especially while trying to work from home.
I was planning on upgrading to gig1 but I assume that’ll have no effect as my speeds are still good and it’s just the latency and packet loss causing all the issues.
Any suggestions other than to wait for who knows how long?
Tags (1)
ince1
  • 10
Re: Latency and packet loss causing issues
Can't seem to add the broadband quality monitor.
Harvey_H
  • 188
  • 22
  • 46
Send me a PM with your Account Number and Area Reference and I'll look into this for you.
To send me a Private Message just simply click the link below:
Click Here
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a Service Field Technician at Virgin. However, all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
ince1
  • 10
So having been told there's high utilisation on my road and there's been no change to the internet
"There is work currently being done to fix your area and on out system is says:
Estimated End Date
14:55  21 April 2020"
My BQM is still utterly horrendous - any updates?
I've added the live view link - Live link
ince1
  • 10
Any help? Adding these too just in case you need them
1323000000938256 qam24
213900000011.438256 qam1
314700000011.640256 qam2
415500000011.338256 qam3
516300000011.138256 qam4
61710000001140256 qam5
717900000010.538256 qam6
818700000010.538256 qam7
919500000010.140256 qam8
102030000009.638256 qam9
112110000009.538256 qam10
12219000000938256 qam11
132270000008.938256 qam12
142350000008.938256 qam13
152430000008.538256 qam14
162510000007.638256 qam15
172590000007.538256 qam16
182670000007.638256 qam17
192750000007.438256 qam18
202830000007.838256 qam19
212910000008.838256 qam20
22299000000938256 qam21
233070000008.840256 qam22
243150000008.940256 qam23
1Locked38.950
2Locked38.960
3Locked40.3160
4Locked38.6180
5Locked38.9200
6Locked40.370
7Locked38.950
8Locked38.960
9Locked40.370
10Locked38.950
11Locked38.960
12Locked38.950
13Locked38.950
14Locked38.650
15Locked38.980
16Locked38.900
17Locked38.6140
18Locked38.9140
19Locked38.960
20Locked38.6110
21Locked38.900
22Locked38.940
23Locked40.360
24Locked40.36
0
1537000003.979512032 qam2
2394000003.929512032 qam4
3462000003.979512032 qam3
4603001194.1512032 qam1
3ATDMA0000
4ATDMA0000
ince1
  • 10
04/05/2020 23:14:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:12:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:12:6Warning!Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:12:6Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:11:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:10:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:09:57criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 23:07:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 09:47:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 10:52:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 10:52:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 03:39:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 00:10:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 20:26:26ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 16:26:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 15:45:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 06:00:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 01:06:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2020 18:06:58noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2020 18:06:58ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
