co0ps
Latency Issue gig 1- Southampton
I keep experiencing huge jumps in latency and packet loss from my gig 1 connection.  I have called support each time it is power off you router for 20 seconds.
The speed seems pretty consistent however the latency is ridiculous.
I use a wired connection, have done all the usual checking.  I am wondering if someone from VM is around on this forum to do a line check 🙂
Chris.
  • 15.91K
  • 687
  • 1.56K
Re: Latency Issue gig 1- Southampton
run this speed test
https://www.dslreports.com/speedtest
or run CMD
ping -t 194.168.4.100
and do any speed test see if your latency spikes
co0ps
Yes the problem does seem to get worse when downloading or doing a speed test.  About 25% packet loss and latency jumping to 200-400ms
