lontjc
  • 22
Laptop not reflecting 200MB broadband speed
My wife and I both use laptops with a wired connection.  Both are reasonably recent machines running Windows 10.  We have 200MB broadband.   We just ran speedtest.net simultaneously on both machines.   My PC returns 200MB reading if not slightly higher.  My wife's PC returns 60MB.  What could be choking the speed recorded on my wife's laptop?
  • 26.38K
  • 2.69K
  • 4.88K
Re: Laptop not reflecting 200MB broadband speed
Try changing the ethernet cable to a new Cat5e/6/7 one first - they can fail - and Cat5 cables will limit speeds to <100.
Check its network card is set to 1GB and not the limiting 10/100 speeds. Then ensure its drivers are up to date. If they are ok and still low - do it this way...
As you expect >100Mbps then connect a 1GB enabled computer/laptop, directly to the Hub which you have first put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again in the same modem mode way
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
lontjc
  • 22
Outdated software seems to be the major issue, having tried all the tests given below.  Very helpful.  Many thanks.
conman33158
  • 1.56K
  • 131
  • 295
Super solver
Also don't run the tests simultaneously but individually as one PC will nearly always takes most of the bandwidth unless you're using a router with QoS (Quality of Service) software.
