Laptop WiFi speed slower after I used ethernet
AC0182
I have the 1gig plan and my Hub 6 is producing that speed. All my devices get 700+ on WiFi. My laptop is the best equipped and always pulls the fastest download speeds. Until I plugged an ethernet cable in for about half an hour.
Ever since I unplugged and went back to WiFi, my 900Mb/s+ speeds on laptop are under 200Mb/s. I tried resetting the router, power cycling the router, restarting the network adapter, restarting the laptop. I separated my SSIDs because it seemed like it was using 2.4ghz but that didn't help. It's using the 5ghz band. I also tried manually inputting the DNS.
1 ACCEPTED SOLUTION
Accepted Solutions
AC0182
Update: I did the following two solutions, not sure which worked as the laptop restarted after I did both
1. Chose Network Reset in internet & network -> advanced network settings.
2. In command promp I put in each of the commands below and hit enter.
netsh int ip reset
netsh advfirewall reset
netsh winsock reset
ipconfig /flushdns
ipconfig /release
ipconfig /renew
After this my laptop restarted as part of the network adapter reinstallation process.
Using the ethernet connection did something to my network adapters but I do not know what or why.
2 REPLIES 2
AC0182
netsh int ip reset
netsh winsock reset
ipconfig /flushdns
ipconfig /release
ipconfig /renew
Hi there @AC0182
I am so sorry that you have faced an issue with your service and thank you so much for updating us, can I ask if this is now resolved as you have marked your response as an accepted solution?
