Wasey
Message 1 of 8
Lag/buffering
Super hub 3 has seriously let me down for the past 2 wks every 1 to 10 mins it is buffering on YouTube & I cannot even use Prime Video at all.I think it’s time to tell Virgin to shove the hub 3 were the sun don’t shine.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Lag/buffering
What is your contracted speed ?
How are you connecting the device to the Hub, Wi-Fi or ethernet cable ?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Wasey
Message 3 of 8
Re: Lag/buffering
power line adapter Ethernet,speed is 70 to 60 on average
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
Re: Lag/buffering
Contracted speed ?
Wasey
Message 5 of 8
Re: Lag/buffering
60 to 70 Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
Re: Lag/buffering
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 8
Re: Lag/buffering
Can you please
Emma_C
  • 8.28K
  • 512
  • 559
Message 8 of 8
Re: Lag/buffering
Hi Wasey,
Very sorry for the delay in getting back in touch, we have been busier than usual.
I've had a look into the back end of things for you and can see since posting you've been in touch with the team who have been able to provide further assistance.
Please do pop back if you need anything else.
Emma_C - Forum Team
