jaydoyle
Just joined
Message 1 of 5
Lag Spikes
Anyone else getting intermittent lag spikes over the past few weeks? Every time i run a speed test itll be fine then drop for a second then go back up, but this drop is causing me huge problems. These things normally last a few hours but its happening every couple of days now and its ridiculous.
jaydoyle
Just joined
Message 2 of 5
Re: Lag Spikes
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 5
Re: Lag Spikes
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
Re: Lag Spikes
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
Re: Lag Spikes
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
