section_32
  • 21
Message 1 of 12
Keep timing out, unstable connection
over the last week or so i've had constant connection issues with our broadband. Rebooting the router on a daily basis, sometimes more than once a day. Response times are incredibly slow or timing out altogether. i raised this a few months ago and an engineer came onsite and couldn't resolve the issue but as it wasn't as bad back then we decided to leave it. I have included some screen shots as examples.
network log.pngping bbc.pngping google.pngbroadband monitoring.pngupstream channels.png
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 12
Re: Keep timing out, unstable connection
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 12
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
JitteryPinger
  • 1.87K
  • 207
  • 392
Super solver
Message 4 of 12
Wow, looks interesting, something is certainly broken somewhere.
Unfortunately this looks to also be affected by a congestion (utilisation) issue, it's not a quick or easy fix, hopefully if this issue has been ongoing for some time it might be closer to a resolution.
Hold on here and someone from the Virgin Team will have a look and give your more info however could be a few days or so.
If I've helped let me know 🙂
10 year's managing 9 Virgin Media accounts, and things never got any better, closed last 4 accounts since January 2021 :L
I give 'my' experience to help where possible.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 12
At the top of the next hour please try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight by slackening off and then retightening.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check your live BQM again in half an hour or so.
section_32
  • 21
Message 6 of 12
Broadband monitor Live
here's the live link as requested
section_32
  • 21
Message 7 of 12
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
7.9
40
256 qam
9
2
211000000
7.9
40
256 qam
10
3
219000000
7.8
40
256 qam
11
4
227000000
7.8
40
256 qam
12
5
235000000
7.5
40
256 qam
13
6
243000000
7.1
40
256 qam
14
7
251000000
7
40
256 qam
15
8
259000000
6.9
40
256 qam
16
9
267000000
7.1
40
256 qam
17
10
275000000
7
40
256 qam
18
11
283000000
7.4
40
256 qam
19
12
291000000
7.4
40
256 qam
20
13
299000000
7.4
40
256 qam
21
14
307000000
7.3
40
256 qam
22
15
315000000
7.4
40
256 qam
23
16
323000000
7.6
40
256 qam
24
17
331000000
7.5
40
256 qam
25
18
371000000
7.8
40
256 qam
26
19
379000000
7.8
40
256 qam
27
20
387000000
7.9
40
256 qam
28
21
395000000
7.9
40
256 qam
29
22
403000000
7.5
40
256 qam
30
23
411000000
7.4
40
256 qam
31
24
419000000
7
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
7
0
2
Locked
40.3
14
0
3
Locked
40.3
13
0
4
Locked
40.9
7
0
5
Locked
40.3
14
0
6
Locked
40.3
18
0
7
Locked
40.3
6
0
8
Locked
40.3
14
0
9
Locked
40.3
14
0
10
Locked
40.3
9
0
11
Locked
40.3
8
0
12
Locked
40.9
5
0
13
Locked
40.3
17
0
14
Locked
40.3
18
0
15
Locked
40.9
18
0
16
Locked
40.3
6
0
17
Locked
40.9
23
0
18
Locked
40.3
1
0
19
Locked
40.3
15
0
20
Locked
40.9
24
0
21
Locked
40.3
8
0
22
Locked
40.3
10
0
23
Locked
40.3
16
0
24
Locked
40.9
10
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
44.5
5120
64 qam
1
2
39400000
43.5
5120
64 qam
4
3
53700000
44.3
5120
64 qam
2
4
46200000
43.8
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
4
0
4
ATDMA
0
0
0
0
section_32
  • 21
Message 8 of 12
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID
224782
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
224781
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Time
Priority
Description
14/01/2021 02:08:48
critical
14/01/2021 00:52:52
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 16:27:26
critical
13/01/2021 15:57:16
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 06:35:27
critical
13/01/2021 03:34:4
Warning!
13/01/2021 01:10:28
critical
13/01/2021 00:23:54
Warning!
13/01/2021 00:21:6
Error
Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 22:40:12
critical
12/01/2021 22:31:54
Warning!
12/01/2021 13:22:30
critical
12/01/2021 13:10:37
Warning!
12/01/2021 08:33:6
critical
11/01/2021 23:14:40
notice
11/01/2021 09:52:10
critical
11/01/2021 09:46:23
Warning!
11/01/2021 06:06:44
critical
11/01/2021 05:12:0
Warning!
10/01/2021 22:44:28
critical
section_32
  • 21
Message 9 of 12
i can't do this right now as i work from home and kids home schooling at the moment means i can't restart the router currently. however i would note that the engineer that came on site a few months ago replaced all the co-ax connections
section_32
  • 21
Message 10 of 12
interestingly, since reporting the issue it seems to have dropped back to normal. no action taken on my end.
BQM
