Shelliak
Keep losing broadband connection
My router keeps disconnecting, worked fine for over a year now but today just keeps disconnecting for a couple of minutes then reconnecting which is becoming really irritating, service status says no issues in the area. Any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Keep losing broadband connection
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
