LS1231
  • 39
Message 1 of 100
Just joined with slow speed
I joined virgin media 4 days ago with the M350 broadband and i've done several speed tests on my desktop computer and my phone and im yet to see anything over 130mbps. I've also gone through the "WiFi wins" and things like that and made sure everything is connected plus resetting the hub but nothing is changing. The speeds have gone as low as 78 bytes on steam when downloading a game and it said it would take over a year to download and as slow as 4mbps on speedtest.net.
gary_dexter
  • 30.48K
  • 1.89K
  • 4.05K
Message 2 of 100
Re: Just joined with slow speed
Speeds are only guaranteed over a wired connection not wireless.
Aureliano
Message 3 of 100
Don't think so Gary, I am wired and also joined virgin media 3 days ago with the M350 broadband and I can get past anything over 165 mbps. Have been told that due to COVID-19 it would be slower, but that's definitely too slow.
gary_dexter
  • 30.48K
  • 1.89K
  • 4.05K
Message 4 of 100
Aside from the fact this isn’t your post, what are you Speedtesting from?
LS1231
  • 39
Message 5 of 100
my friend has the exact same package and he is able to get over 360mbps on wireless and he has a lot more devices in his house so you would expect it to be worse
gary_dexter
  • 30.48K
  • 1.89K
  • 4.05K
Message 6 of 100
Wireless environments vary from house to house.
What are you wired speeds like?
  • 22.45K
  • 2.4K
  • 4K
Message 7 of 100
As Gary g=has advised to both of yous test this way...
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "TO" the Hub are guaranteed. So, you need to test speeds directly.... that's on an ethernet cable (Cat5e/6) connected to a GB enabled computer/laptop, with up to date drivers with the Hub in modem mode. Test at speedtest.net to your nearest VM server - try 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown software or other connected devices are limiting speeds on tests.
Report back what that gets.
LS1231
  • 39
Message 8 of 100
i dont have a laptop that i could connect and my desktop is 1 floor above the hub so it would be hassle moving anything but i could test my ps4 if that would work as a reliable test
Anonymous
Not applicable
Message 9 of 100
Try splitting your 2.4 and 5 Ghz SSIDs into two, so you know you are definitely connected to the best available connection for your device.
Keep in mind that your friend may have a device that is capable of higher speeds.
My LG G6, for example, speedtests at 160 - 200Mbps even in the same room as the HUB 3, even though I have a 350Mbps package.
However, I consistently get full speed on wired devices.
gary_dexter
  • 30.48K
  • 1.89K
  • 4.05K
Message 10 of 100
No consoles aren’t a reliable way to speedtest.
